Need advice
Old Aug 5, 2012 | 07:44 PM
sand_fiend's Avatar
sand_fiend
Need advice
I did the ac mod today and as i was putting the cold air back on i ran across a forgotten problem i had.
on the passenger side head where the wires from the harness plug in to the valve cover gasket.
The wires had been stripped back from the plug by ford to check for the reason my truck died before i found this site.
I know they did it because it was not like that before i had it worked on.
anyway, i think i asked around here about a new plug or harness and forgot about it until today.
So, What i did for now was use some liquid electric tape on the plug and wires. will this be good enough or should i find and solder a new plug in ? The truck runs great..
Any input ?
Old Aug 5, 2012 | 07:51 PM
BigAlsPSD's Avatar
BigAlsPSD
You will probably be fine, just remember it if or when you start to have issues. Personally I wouldn't worry if it wasn't showing any signs of an issue. But they shouldn't be too hard to find, as Clay has them.
Riffraff Diesel: Valve Cover Gasket Connector Pigtail 99-03
ithaca1230
Oct 28, 2013 02:59 PM
URDADDY
Feb 23, 2012 10:31 PM
jeronlines
Sep 26, 2011 04:31 PM
kawa
22
Sep 17, 2010 03:06 PM
