Tip: Loosly install the bolts at the exhaust manifold to up pipes and then connect everything else. Come back and tighten the manifold bolts last. If you tighten them first, then it will be a bear to connect the collector to the turbo outlet...
you sound like a voice of experience on this... the Excursion I just picked up, I am pretty sure has leaking up pipes. I have not crawled under it to confirm it yet... I would like to get it all sorted before momma starts driving it all the time. I guess I should call you so we can scan it, and I can get your "professional" opinion
