Aerostar Ford Aerostar
Headlight switch questions
Old May 12, 2003 | 10:33 AM
jeff_67cougar's Avatar
jeff_67cougar
Question Headlight switch questions
My 93 Aerostar is going through headlight switches every 6 months or so. When the lights are on the dash lights will go out.
6 months ago the headlights and dash lights quit suddenly. I have replaced the headlight switch twice in the last year or so. First I used an Autozone special. The second was a motorcraft from the dealer.
I remember a recall a while back dealing with overheating headlight switches. The dealer installed a relay. Could this relay be bad now? Does anyone know the p.n. or anything else about the relay?
BTW the headlight switch connector shows that it was very hot at one point. It has brown areas and signs of melting.
Thanks for your help
Jeff
Old May 12, 2003 | 08:31 PM
eehoepp's Avatar
eehoepp
My local dealer parts guy recommended replacing the harness connector when replacing the headlight switch. It was under $20 & took about 30 minutes to solder in. When the headlight switch goes, it apparently melts the connector. After 1-1/2 years I haven't had any further headlight troubles. As a bonus, the wire length on the replacement harness lets you extend the harness a few inches which makes it a whole lot easier to reassemble the switch & panel.
Cheers,
Eric
Old May 13, 2003 | 07:03 AM
jeff_67cougar
Thumbs up Headlight switch questions
Thanks Eric I'll check into the new connector.
Jeff
Robrt32
Apr 30, 2014 10:00 AM
TAT2DUP81
Feb 24, 2011 12:22 PM
Festus Hagen
Aug 2, 2010 12:56 AM
Rovert
Bronco II
Apr 22, 2005 08:47 PM
palace_master
Electrical Systems/Wiring
Dec 18, 2004 12:00 AM
