Bronco II Ford Bronco II
Headlight Relay location?
Old Apr 17, 2005 | 12:44 PM
Rovert's Avatar
Rovert
Howdy, folks! First time poster, here.
Having a problem with the headlamps on a 88 Bronco II. Brights work, parking lamps fine, but regular driving headlights don't go on. Already replaced the dash pull/dimmer switch. I'm thinking it's either the multifunction stalk switch on the steering column, or a headlight relay somewhere. Can one of you folks point me in the right direction on one or both of these questions:
1) Is there a headlight relay, and if so, where is it located?
2) Is there a recommended test procedure to see if the multifunction switch is bad?
Thanks so much in advance!
Old Apr 17, 2005 | 07:22 PM
bronco2man's Avatar
bronco2man
Smile
could be your low beams are burnt out?
Old Apr 17, 2005 | 07:43 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
My 1989 doesn't have a relay. I would suspect the multifunction switch or an open in the r/bk wire going to the lights.
I can email you the test procedure for the MFS if that would help.
Old Apr 17, 2005 | 09:49 PM
Rovert's Avatar
Rovert
Ken, thanks so much for replying. Suspecting the MFS, not knowing if/where a relay was, and having time to burn, I removed the steering wheel column and found the problem was a shorted switch with melted contacts. Do you have a recommended source for a replacement? Is this an item available from a local Auto Parts dealer like Pep Boys?
What troubles me is the REASON this burned out. Is this an item that just "goes" after a certain amount of time, or should I be looking for a deeper problem that caused the failure?
Thanks!
Old Apr 19, 2005 | 07:26 PM
Ken00's Avatar
Ken00
I would try your local parts stores or an online store, Ford would be $$$. They seem to be a common problem on Fords and other brands, check the wiring in the connector carefully too.
Old Apr 22, 2005 | 10:18 AM
Rovert's Avatar
Rovert
Ken, thanks so much for your help. We did find one at the local AP store. Appreciate your support!
Old Apr 22, 2005 | 08:47 PM
Ken00's Avatar
Ken00
Glad to hear you found one.
ligito
Sep 20, 2016 06:56 PM
cecilt
Sep 11, 2016 03:40 PM
HKusp
Dec 16, 2013 06:35 AM
jaylie
Electrical Systems/Wiring
20
Oct 7, 2011 07:22 PM
el conquistador
1983 - 2012 Ranger & B-Series
13
Apr 7, 2005 09:50 PM
