Carb 4.9 l
Old 08-03-2012, 10:18 PM
JWGCROWLEY's Avatar
JWGCROWLEY
JWGCROWLEY is offline
Carb 4.9 l
I have an 85 ford f150 with a 4.9l 300 i6 I currently have a single barrel carb with manual choke my choke is all bent and broken so rather than fix it I want to buy a new carb I was looking for a 4 barrel. Does anyone know where I can get a good and cheap
Old 08-04-2012, 09:37 AM
Harte3's Avatar
Harte3
Harte3 is offline
eBay, Craig's List, Junk yard, garage and yard sales, etc. Keep in mind that "good" and "cheap" are sometimes contradictory terms.
Old 08-04-2012, 02:20 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
I guess my question is Why?
Old 08-04-2012, 03:38 PM
Harte3's Avatar
Harte3
Harte3 is offline
Good question...because to use a 4v carb will necessitate a 4v intake, heat to the intake (minor detail but necessary) if not using the stock exhaust manifold with an Offy intake manifold, probably conversion to a DS2 ignition...and all this done will not necessarily be done on the "cheap".
Old 08-04-2012, 05:30 PM
JWGCROWLEY's Avatar
JWGCROWLEY
I want to make this motor as good as I can I am planning on getting as many performance parts as I can even if there may not be many so I would rather go for a 2 or 4 barrel and I mean cheap as in the best deals not garbage. My truck is pretty much mint and I got a steal on it so I want to make this my toy
Old 08-05-2012, 12:48 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
Ok, I understand.....
but something to consider, the OEM 1V carb is really not all that bad and there is really no performance gains when comparing a 2v to 4V carb....
Without changing/regrinding the cam, the amount of gain with a replacement intake & 2V/4V carb is really, well, it's like giving it a tune up. What I would recommend is to 1) ensure the ignition is in good shape, 2) kick the timing up a tad, 3) differential gears & even 4) headers.....
#1 & 2 will make it feel better, #3 particularly will make it more responsive than spending $ on a carb/intake, etc....especially if you have 300 gears and/or larger tires.
Old 08-05-2012, 04:19 PM
JWGCROWLEY's Avatar
JWGCROWLEY
My choke is broken as it is this so do you suggest I just go buy another 1 barrel
Old 08-05-2012, 06:30 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
I would visit a local carb rebuilding shop.....they should either have or can get the oem quality replacement parts- typically much better than a "rebuilt unit" (although it does depend on the rebuilder)....and you will have a good running truck!
Waltg78
03-20-2008 08:09 PM
pchristman
11-10-2006 08:54 PM
JLmissouri
27
02-01-2006 08:19 PM
rayray2k22002
08-18-2002 10:33 PM
topo4u2
05-11-2002 11:07 AM
Quick Reply: Carb 4.9 l
