Lost boost
Old Aug 6, 2012 | 11:49 AM
Tom's Avatar
Tom
Originally Posted by parkland
I agree to an extent; I think peak boost would remain the same, it would just take longer to get there.
Remember that to pressurize air that's less dense to the same peak pressures as you would at sea level requires much higher compressor RPMs. So if the turbo had that much extra capacity then it would be possible, but the 6.7L doesn't. Which is the most common theory as to why the PUT.com Rumble in the Rockies test ended like it did. I asked an engineer at FoMoCo about this directly and this was the explanation that I got, but I can't post the exact response publicly.
Old Aug 6, 2012 | 12:02 PM
RobFlag's Avatar
RobFlag
Crazy, agree with slower response but would have thought that the waste gate would still not open till max programmed boost (24 psi?). Haven't had a chance watch the boost on the Edge at lower altitude but will next time and see if it's different.
Old Aug 6, 2012 | 04:51 PM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Originally Posted by screwy
Huh... ok then. It's been fine since. I can just see the service advisors of the future.. "Have you tried turning it off and back on again?"
Have you re-booted the computer yet......
Not really funny..........
I have had 2 things happen:
1) Boost fluctuated about 10psi up & down on a steady level hi-way. Twice. Shutdown.......wait 1 min or less. Restart....and life is good.
Told the dealer, and he confirmed I am not the only one and Ford is working on it.
2) Start down the Hi-way and I see that fuel milage is terrible. Stop, re-boot the truck. Milage back to where it should be. .....and, no, I didn't see any re-gen notice. I do realize that when the re-gen cycle begins the mileage drops a bunch.
Old Aug 6, 2012 | 05:05 PM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Peak Boost.......
I live at just under 4000 ft. in Great Falls Montana. Peak boost over 20psi.....
Going over passes, like Macdonald pass near Helena MT. Over 6300ft. Boost over 20psi.....
2011 F-350 6.7
Old Aug 6, 2012 | 07:26 PM
Tom's Avatar
Tom
I wasn't going to post this, but I think it's appropriate:
Originally Posted by Anonymous
I've stayed away from that particular thread and the those related as the nature of the comparison was based on exploiting practical/functional limits of the technological differences between the two powertrains. In short, one turbo design has an advantage in efficiency at altitude in that it can move more air versus the other turbo charger having a more balanced overall mapping for things like throttle response, fuel economy, etc.
The other major factor that comes into play is the engine power de-rate strategy that is activated when turbo operating temperature limits are reached. Each design has its thermal limits before things start to melt. I don't have the turbo mapping benchmarking data between the two, but assuming that the single compressor wheel is more efficient at altitude, it's probably safe to say that the 6.7L de-rates power slightly sooner than the 6.6L in that specific operating range. I'm quite sure that the engineering teams from both camps understand the others technical limitations considering that honeywell/garret supplies both turbos and that turbo selection is made after an exhaustive review of which alternative delivers the best characteristics for the given set of requirements for a particular application.
Old Aug 7, 2012 | 04:16 PM
2horses's Avatar
2horses
Yes, I have had it happen once as well, a "reboot" fixed mine as well. Has only happened the one time so far, have almost 24K on her.
Now watch, it'll probably happen today when I try to leave work......
Old Aug 7, 2012 | 04:34 PM
RobFlag's Avatar
RobFlag
Here is an example from today:
Full throttle from about 5 MPH to about 75 MPH. Boost never goes above 18 PSI. APP1d is the position of the pedal. Not sure why it doesn't say 100% cause I was pushing plenty hard! Any thoughts?
[URL="http://youtu.be/RUYUSk73rqE"][COLOR=#000080]
Old Aug 8, 2012 | 06:42 AM
kper05's Avatar
kper05
I tested boost this morning with the Edge and I could keep it at 21 PSI but I use manual mode.
This doesn't fix whatever might be going on with your truck but the Edge does report it correctly.
My area is around +/- 550 feet above sea level so that helps, too.
Bruteskeg
6.7L Power Stroke Diesel
Jul 28, 2015 08:13 PM
jermort
13
Jul 3, 2011 09:59 AM
lakewood
Sep 10, 2010 04:17 PM
chadjones99
Apr 7, 2006 10:16 AM
