Sponsored by: Real Truck
checking rear end on F250??
Old May 12, 2003 | 08:15 AM
Jetsfan68's Avatar
Jetsfan68
Question checking rear end on F250??
The VIN code on my 2001 F250 states 4.30 rear but I also heard it would be posted on the differential itself. Well- I crawled under there and looked and did not see anything- Where would it be stamped?
Old May 12, 2003 | 09:13 AM
Karic's Avatar
Karic
My '03 has an aluminum tag with the code embossed on it on the rear diff. cover. It's held on to the right hand side by two of the cover bolts.
Rick
Old May 12, 2003 | 12:03 PM
jetjock16's Avatar
jetjock16
The rear ends are always coded for some reason, and just trying to guess from the codes can be confusing.... Check the numbers on the front axel, they post the gearing clearly up there, no codes, the ratio will be stamped right on the tag.... The rear would obviously be the same as the front so youd have your answer.
AllAboutDaZ
Feb 28, 2014 04:12 PM
old blue beast
May 30, 2013 09:31 AM
Raymond
Mar 8, 2013 06:58 AM
cowboyty
Mar 9, 2007 02:53 PM
Flabiker3
Aug 16, 2003 07:18 AM
