rear end gears
Old Aug 3, 2012 | 11:01 AM
timmyboy76's Avatar
timmyboy76
rear end gears
Sure i got the 10.50 rearend, but would these work...
Ford F250 / F350 4.10 Ring & Pinion Set
Old Aug 3, 2012 | 11:07 AM
theenforcer's Avatar
theenforcer
i dont think so, you might have to change the whole diff..
im sure others will chime in with a definate answer for ya
Old Aug 3, 2012 | 11:19 AM
Shake-N-Bake's Avatar
Shake-N-Bake
I think the ring gear diameter is too small...
Here is a link with some useful info...
Ford 10.25 & 10.50-Inch Axle Tips - Four Wheeler Magazine
Old Aug 3, 2012 | 11:59 AM
CSIPSD's Avatar
CSIPSD
It will fit fine. You have to use a 10.25 install kit...
Its done all the time.
Old Aug 3, 2012 | 12:03 PM
timmyboy76's Avatar
timmyboy76
thx for replys guys. CSIPD, from what ur say'n, looks like i need whats mentioned in the "article" Bake posted, with the new wider diameter bearing as well....?
Old Aug 3, 2012 | 12:05 PM
Shake-N-Bake
Good info Joe. I didn't even know they made a kit for that purpose.
There was some blurb on the article in the link...
Fact: This axle received a larger ring gear, which improved its overall strength and addressed the premature failure issues of the 10.25-inch axles when used with 4.10:1 or numerically higher gear ratios. Unfortunately, it was designed with a smaller pinion bearing than its predecessor.
Is there any truth to that statement? If so, would the 10.25 kit have an upgraded pinion bearing?
dohertycm
2009 - 2014 F150
Oct 23, 2015 05:28 AM
jaye
Mar 25, 2009 10:47 AM
sampson0861
6.4L Power Stroke Diesel
May 5, 2008 10:19 AM
LiftedFx4F250
Dec 2, 2007 10:49 AM
part time farmer
Jan 27, 2004 06:27 AM
