Ok im back. Heres the issue, transmission exploded while driving. (c6) swapped trans and all the related parts with an np435. Everythings together and what not.
The issue is the starter wont crank the flywheel at all. Its brand new as of today. The bendix sinks all the way into place but wont spin it. Tried spinning the motor manually but it wont bugde. However the engine would rotate before the transmission was installed. (no its not in gear lol) im lost here. I would say the engines locked up with the last time it ratated to the trans being on was only a few hours. Any ideas???
If it is a 351W or 302, did you change out the starter? There's a different starter for the autos vs manual transmissions. Dunno about the 300 nor 460. But the 351M/400 just have one starter.
The trans out put shaft spins free. Could it be the pressure plate is too big for the bell housing? As in being wedged between the flywheel and the bell housing. The pressure plate is from an early 90's sbf mustang.
I wouldn't have thought so, but I don't know. Are the flywheel, bellhousing & other parts all correct? It sounds like it might be time to start unbolting again.
Originally Posted by JJray
And how much of a power difference should be noticed?
With my 351W, I got a good improvement on acceleration, but particularly with power pulling up hills. It seems the more that was asked of the engine, the more the C6 would rob.
But I gained only about 1 mpg if running empty @ 55mph.
I think towing/loaded/working, the mpg gain would be significantly more, but I don't have those figures.
The bell housing is a small block ford bell. The flywheel's for a 351w which is what i have, however if this trans takes a certain flywheel then i could have the wrong one. But i think its time to unbolt stuff too and just make sure.
Ok trans is back off and everything is spinning freely again. Time to get a new clutch set but will a clutch set for an 83 351w work on a trans from a 78 79 300 il6? I have the original pressure plate. Its the old flat head style, so will or should a new style work?
