This time its not electrical!
Old Aug 6, 2012 | 05:44 PM
Gary Lewis's Avatar
Gary Lewis
Originally Posted by JJray
Ok trans is back off and everything is spinning freely again. Time to get a new clutch set but will a clutch set for an 83 351w work on a trans from a 78 79 300 il6? I have the original pressure plate. Its the old flat head style, so will or should a new style work?
Yes, the clutch set for a 351W will work on an NP435 from a 70's 300 six. Just make sure your clutch set is right for the engine's flywheel and the splines will match the tranny's input shaft.
As for the "flat head style", I don't know what you mean.
Old Aug 6, 2012 | 08:45 PM
JJray's Avatar
JJray
Iv heard it called a flat head style pressure plate so i assume thats the name. But instead of have alot of fingers it has 3 thin fingers and alot of springs around the diameter
Old Aug 7, 2012 | 02:22 AM
Ken Blythen's Avatar
Ken Blythen
That style of pressure plate is lighter duty than the diaphram type.
Lucky that the bellhousing didn't get cracked - they're pretty delicate when it comes to out-of-the-ordinary stresses.
If you can, I would just buy a complete kit to suit the engine/flywheel you have, then everything will be new & matched, & will give you good service.
Also, check that you order the right diameter kit (10" vs 11") for your flywheel - some are drilled for both sizes, others aren't.
Do you have the block plate to install in front of the b/housing?
Old Aug 7, 2012 | 10:20 AM
JJray's Avatar
JJray
Oh ok and my flywheel has the 2 dif diameter sizes already. So which one should i use? And yes the plate is there too.
Old Aug 7, 2012 | 10:52 AM
Gary Lewis's Avatar
Gary Lewis
The larger the clutch the more torque it can handle. However, too large of a clutch can be a problem. If your engine is stock and you don't do much towing go with the stock size. If you've upgraded the engine or tow a lot then go with the larger size.
Old Aug 7, 2012 | 01:40 PM
JJray's Avatar
JJray
Oh ok thanks
NP435Bronco
15
Dec 1, 2025 09:45 AM
WilliamKG88
19
Jun 9, 2015 02:09 PM
agaristo77
1978 - 1996 Big Bronco
24
May 11, 2012 11:34 AM
ginch66
Nov 6, 2011 01:41 AM
vinny80
May 31, 2011 08:37 AM
