headers
Old Aug 2, 2012 | 12:28 PM
Schickel's Avatar
Schickel
headers
Anybody got any tips on a first timer puting headers on a 400m? Im replacing my stock manifolds and just lookin for any tips
Old Aug 2, 2012 | 01:06 PM
FordmanShane's Avatar
FordmanShane
Welcome..so what are you working with? Headers can warp, I had BBK's on a 351. I was changing the gasket and nothing lined up right didn't figure headers would warp had to get help one had to pry and the other one bolted.
Old Aug 2, 2012 | 03:08 PM
Schickel's Avatar
Schickel
I got some summit headers en route to my house. My real concern is getting the manifolds off
Old Aug 2, 2012 | 03:20 PM
hivoltj's Avatar
hivoltj
Be careful loosening the bolts, they tend to break off. Also take the nuts off of the motor mount and jack up the motor a little.
Old Aug 2, 2012 | 03:21 PM
Stinky7-11's Avatar
Stinky7-11
1.) Hedman Headers, 351M 400
2.) Hedman Headers, 351M 400
I'm going to assume your 400m is in a 77.5-79 f150/f250 4x4 pick-up, if so here are both styles. Hedman does offer the chassis exit in a premium model with thicker flanges and ceramic coating but they $$$. Some don't mind but I would weld on standard exit flanges, I don't like the ball and socket style supplied. I have Hedman and am happy, i'm sure you will get different opinions. As far as installing them, the tech sheet that came with mine outlined most of the knuckle busters you will encounter!
Old Aug 2, 2012 | 05:13 PM
hasteranger's Avatar
hasteranger
spray the bolts with PB blaster 48 hours before hand, completely soak them. Then do it again 24 hours before hand. Then do it again just before you remove them.
Use only a 6 point socket or 6 point box end wrench.
Heat the stubborn ones up till they glow, sometimes it helps to get them off.
Mike O.
24
May 2, 2007 02:52 PM
hsfbfan
Exhaust Systems
Jul 26, 2004 08:14 AM
coastie
Exhaust Systems
May 16, 2000 01:54 PM
