cost differrnce
Old Aug 1, 2012 | 07:41 PM
Chris Guthro's Avatar
Chris Guthro
cost differrnce
What would the cost advantage between a 351 stroker either a 393 or a 408 be compared to buildijg a 460? And what would the power outputs be?
Old Aug 1, 2012 | 07:45 PM
garthneddy's Avatar
garthneddy
You can build a budget 393 with factory 351 rods, 302 pistons and a stroker crank. Cant get much cheaper then used factory parts
Old Aug 1, 2012 | 08:07 PM
86fordtruck's Avatar
86fordtruck
The Eagle stroker kit I got was about $1300 if I recall correctly. It includes new crank, rods, pistons, rings, and main bearings. With the heads and cam I selected, the desktop dyno says it should produce about 480 hp and 500 ft-lbs of torque. Yes, you can get more torque from a built 460, but it is heavier and uses a different bell housing. I am not sure how much building a 460 would run. Good luck.
Old Aug 1, 2012 | 08:48 PM
Gary Lewis's Avatar
Gary Lewis
Why not build a 400? The big brother to the 351M can put out a lot of torque but weighs less than a 460.
Old Aug 1, 2012 | 09:12 PM
Sw1tchfoot's Avatar
Sw1tchfoot
Most people already have a 351W under the hood.
Old Aug 1, 2012 | 09:16 PM
Gary Lewis's Avatar
Gary Lewis
Exactly! Such a good reason to build up a 400 instead.
cpetersen
Apr 4, 2012 05:16 PM
tutka90
Feb 14, 2011 02:01 PM
rwjr
Jan 13, 2004 04:20 PM
shazam
25
Nov 19, 2002 02:33 PM
Goober
19
Feb 16, 2001 07:46 AM
