Tips!!!
Old May 11, 2003 | 10:50 PM
fordman7988's Avatar
fordman7988
Tips!!!
This summer I plan to build a new 300-6 engine and looking for a few helpful comments on what carb, intake, headders, pistons, and cam to get. I am getting a block from my friend that needs to be bored, but not sure how much and if I can put a bigger crank in it. Im going to drop this in my 88' f-150 4x4 and get rid of that injector crap. Thanks for your time!!!
Old May 11, 2003 | 11:08 PM
kcw12's Avatar
kcw12
Tips!!!
It depends on how much u wanna spend
If your gonan spend alot get some Trick Flow heads A good header with dual outlets a good cam (i wonder how a drag cam would do for a daily driver) Dual 4 bbl intake flat top racing pistons billit rods and a new crank and straight pipes.....
Or the reasonable build
Find ya a old head off a pre 1970 300 six or 240 six Milled Port and polished Bore it over 30 thosands get a 4bbl instake and a 390 cfm carb get a pair of efi exhaust man.
I myself am gonna try to do teh bottom build iwthout the boring out.
Old May 11, 2003 | 11:09 PM
desperado_18_2000's Avatar
desperado_18_2000
Tips!!!
To answer a few of your questions...
Either an Offenhouser or Clifford intake will work for your application, and the prefered carb of choice in 4bbl's is the Holley 390. In 2bbls, you have a choice of either a 350 cfm stock motorcraft/autolite, or a 2bbl made by Holley/Edelbrock.
As for camming, i'm not sure, but something around the 270-ish range should be a good place to start and really make that big six come alive.
Headers are available, either Hedman's or Pacesetters, there may be a few more manufacturers, but i'm not aware of them.
Also another alternative for starting out your exhaust system is to use the stock EFI manifolds, as they flow almost as well as a header, and can be found usually very much cheaper than headers.
As for building a stroker out of it, (bigger crank.) i think Clifford Performance used to offer a stroker crank for the big six that punched it out to 330 cubes, but i've yet to see one of these myself, nor know of anyone else who makes one.
HTH -Tim-
rknctryboy86
Jul 9, 2011 03:39 PM
4wdriver
2004 - 2008 F150
Apr 24, 2006 06:13 AM
JoeKramer
2004 - 2008 F150
Apr 3, 2005 07:46 PM
RyanMiller
Aug 17, 2004 05:59 PM
19903024x4
Missouri Chapter
Jul 18, 2003 12:33 AM
