Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
2003 dt466e no start
Old Aug 1, 2012 | 05:59 PM
bad a$$ roth's Avatar
bad a$$ roth
i have a 2003 dt 466e that wont crank unless u jump the solenoid and wont even sputter when cranking, im a homegrown idi tech and need an idea where to start the injector driver has no power im going to begin by looking for shorts, need ideas where to start troubleshooting any advice is welcome and appreciated
Old Aug 1, 2012 | 09:06 PM
critterf1's Avatar
critterf1
Should be a 40amp fuse near the batteries, check that first. It will cause all kinds of problems.
Old Aug 2, 2012 | 12:03 AM
bad a$$ roth
will do, just outa curiosity is there any sites to get diagrams and diagnostic procedures for these newer trucks? and is there any way to diagnose injectors, pcm, idm, and such without a scantool. preferably a dvom or test light
thank you
Old Aug 2, 2012 | 01:10 AM
1969furd's Avatar
1969furd
you have the 466E so you will need to get the tool,software, to read and access the ECM. i am not sure how propitiatory International is. as far as wiring, i cant help you there
Old Aug 2, 2012 | 01:37 AM
85e150's Avatar
85e150
Some info here:
Dt 466e Trouble Code List - Page 2 - TheDieselGarage.com
First post here make any sense for your truck?
Reading codes on IH electronic engines - Binder Planet Forums
Whole lotta download files here, not sure how they match up to your truck:
Download: International 4300 reading engine codes at Marks Web of Books and Manuals
Scanner--plenty o'cash:
Displaying PROLINK ~SCANNERS by NEXIQ - Diesel Solutions, Inc.~
Old Aug 2, 2012 | 08:59 PM
bad a$$ roth
well needless to say its a POS the guy who had it was a hack. there is no 40 amp fuse in the truck around the batteries under the hood or even under the rug, i got wires spliced everywhere and nothing is even close to being worth it. after testing all the grounds cleaning all the connectors and messing with connectors for about 4 hours key still doesnt work and when u hit it with a mist of ether it almost fires 2 cylinders and just keeps cranking, gonna say bad ecm/ we found a 96 for 4000, so this one is getting stripped and sold
andrewsmith0404
Nov 13, 2014 03:26 PM
David Ziegler
13
Mar 29, 2014 06:48 PM
ataboc
Aug 18, 2010 12:26 PM
szpieleusa
6.4L Power Stroke Diesel
31
Jun 19, 2009 07:15 PM
BigBlueIron
Mar 24, 2008 09:52 AM
