FAN CLUTCH REPLACEMENT
Old 07-31-2012, 08:37 PM
johnsjsj's Avatar
johnsjsj
johnsjsj is offline
GOING TO PUT ON A NEW FAN CLUTCH TOMORROW. PLEASE GIVE ME THE PROCEEDURE FOR THIS JOB
THANKS
Old 07-31-2012, 09:39 PM
cookie88's Avatar
cookie88
cookie88 is offline
Go to the parts store and rent the fan clutch wrench set. Remove the top radiator shroud. Un-thread the fan assembly from the water pump. Unbolt the clutch from the fan. Wrench size is 47mm and thread rotation is counter clockwise.
Install in reverse order.
Old 07-31-2012, 09:46 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Autozone uses a crappy set, try another store like Orileys or the like. The Autozone ones have a loose fit with makes for hard wrenching.
If you follow this link it will take you to the section in my waterpump video where I take off the fan.
7.3L PSD - How To: Replace Water Pump - YouTube
Old 07-31-2012, 10:08 PM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
I'm sure this will get blasted, but I used an air chisel to remove mine, also, the shroud and fan will need to be removed together
Old 07-31-2012, 10:39 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
Same here. Doesn't take much either....they have always popped right off quite easily with the air chisel method.
Old 08-01-2012, 12:19 AM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
If you haen't got an air chisel then get the loaner tools.
I get two kits from Auto Zone because one has the best fan nut wrench and the other the best fan pulley holding wrench.
Old 08-01-2012, 12:21 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
They rent the wrenches separately? They just handed me a box with 6 wrenchs in it.
Old 08-01-2012, 02:18 AM
twags6's Avatar
twags6
twags6 is offline
Yeah. Depends on how swift the person behind the counter is. Our local AZ has some real winners...
Old 08-01-2012, 02:28 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
I applied there (and turned down an interview) and was surprised how extensive their applications are. They make you take a mechanical aptitude test. Granted its not engineer level stuff, it still surprised me.
Old 08-01-2012, 08:55 AM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
I went in and said I need a voltage regulator for a 73 pickup and the guy said whats that. I said oh boy here we go.
Old 08-01-2012, 11:07 AM
PaysonPSD's Avatar
PaysonPSD
No. That's why I saide "two kits". I just use one wrench from each kit.
timmyboy76's Avatar
timmyboy76
i went the last friday for a few sparkplugs, for my skis, and said, i need 2 br8es...well, he put in the "search" box...2br8es...sir, we dont have that part...
Old 08-01-2012, 01:54 PM
GonzoCSU's Avatar
GonzoCSU
GonzoCSU is offline
I worked at an Autozone store for 2 years in college, I applied to be a driver but they said they wanted me on the parts counter. We had about 3 guys who knew their stuff and the rest was whoever they could find. The one kid could never understand why there was a line of people waiting to talk to me but nobody wanted to talk to him.
If you think the people behind the counter are dumb you should see some of the people who walk through the door! We would get people all the time who would buy spark plugs, put them in, then their problem wasn't fixed so they would return them.
Old 08-02-2012, 10:12 AM
johnsjsj's Avatar
johnsjsj
johnsjsj is offline
DONE
GOT THE NEW FAN CLUTCH ON THIS MORNING
Old 08-02-2012, 10:02 PM
cookie88's Avatar
cookie88
cookie88 is offline
Good on ya!
Quick Reply: FAN CLUTCH REPLACEMENT
