Sponsored by: Auxito
Wont start
Old Jul 31, 2012 | 06:49 PM
frmach's Avatar
frmach
Wont start
01 F150. Cranks but no start, will fire with starter fluid spray.
Theft light fast flash, Check engine light on.
Only have one key and don't know what the kid that had owned has done.
Any help much appreciated.
Frank
Old Jul 31, 2012 | 09:18 PM
dbreckman's Avatar
dbreckman
Look for an after market kill\starter switch. If there's an alarm or remote start installed disconnect it and see if it cures your problem.
Old Aug 1, 2012 | 05:28 AM
projectSHO89's Avatar
projectSHO89
He has a PATS problem....
Verify PCM power first by observing the CEL light during bulb prove out. No PCM power = no start.
Old Aug 1, 2012 | 11:10 AM
stevenn1's Avatar
stevenn1
But he said it fires with starting fluid.
Which leads me to believe its a no fuel delivery issue. Does PATS System effect the fuel? If not, I would check fuel pump fuse, then the wiring, then the pump.
Old Aug 1, 2012 | 02:30 PM
projectSHO89
A PATS event in an F150 shuts off the injectors. It will still start on a spray can even with PATS triggered.
The PATS light is fast flashing - he has a PATS problem.
Old Aug 1, 2012 | 04:53 PM
frmach's Avatar
frmach
Wont start
If a OB scanner reads out the correct VIN# does it mean that the PCM is the correct one for the truck?
Armyrules2
20
Aug 17, 2018 07:13 PM
WinterBorn
1997 - 2003 F150
Jul 13, 2018 07:19 PM
dblake37
1997 - 2003 F150
13
Nov 24, 2014 06:44 AM
ford7379trucks
Sep 18, 2009 11:01 PM
Finally
23
Jun 12, 2006 03:45 PM
