some quick general questions about the 400
Old 07-31-2012, 12:54 PM
vic_v8's Avatar
vic_v8
vic_v8 is offline
Sorry for the easy questions, but I'm a Chevy Expert, not much of a Ford Engine guy.
1. Is the Harmonic Balancer keyed (only goes on one way)? Mine is rusty and can't find the timing line for TDC. I marked it after I brought the engine to TDC, but I want the real mark so there is zero doubt in my mind.
2. To do the Timing Chain, does the front of the oil pan need to be dropped (like a SBC) to remove the timing chain cover?
Old 07-31-2012, 07:03 PM
crsmiffy's Avatar
crsmiffy
crsmiffy is offline
The balacer is indeed keyed. it only goes on one way so if you can find the marks somehow, they should be fine.
Dont know about the chevy, but the trick is you can get the timing cover off with the pan on, but you wont be able to get it back on with the new seals without removing the sump first. Found that out the hard way LOL.
Old 08-01-2012, 05:51 PM
wyoming4x4's Avatar
wyoming4x4
wyoming4x4 is offline
yes!
timing chain, pull dampner and pull waterpump then timing cover. once pulled you'll figure out the keyed dampner situation. forgot drain coolant first Ha! ha!.
DBGrif91
09-15-2013 12:55 PM
Runboy
06-14-2013 01:28 AM
snapper1
04-18-2003 01:23 PM
rayray2k22002
12-02-2002 07:53 PM
rayray2k22002
11-30-2002 07:26 PM
Quick Reply: some quick general questions about the 400
