replacing valve stem seals
Old May 11, 2003 | 08:28 PM
trixie's Avatar
trixie
I'm planning on replacing the valve stem seals on my 390 later this week...the manual says to keep to valve in place with an air compressor, and I don't have an air compressor. My dad tells me the shadetree method is to shove some rope in the spark plug hole and turn the engine until the rope is pushed up against the valve... anyone ever try this method and had good luck? or would I be better off just getting an air compressor? thanks.
Old May 12, 2003 | 12:32 AM
millertime300's Avatar
millertime300
Rope would work fine, but I always have the heads of when I do that kind of stuff. You might be able to use fine wire and wrapp it around the valse stem to keep it in place.
Old May 12, 2003 | 11:04 AM
Mike G's Avatar
Mike G
Hey Trix:
I just did the rope deal a few months ago on my 352. Worked pretty good but here are a few pointers. Of course, turning the motor is done by hand on the crank nut, not with the starter... Get a rope that is just a little slimmer than the spark plug hole. The bigger rope is easier to work with. I also sinched mine up then compressed the valve spring and tested the secureness of the valve. Some took a little re-jockying to get it to the point where I was comfortable. The whole process of 16 valve seals took about 6 hours, off course that was broken out into two evenings between favorite car shows on the tube... Rope is only about $1.00, compressor is considerabley more expensive, but then you have a new toy in the garage to play with!
--MG
Old May 12, 2003 | 01:29 PM
rebocardo's Avatar
rebocardo
The 390 is the first engine I have taken apart with this type of valve stem keeper, so I had problems doing mine. I *thought* I was doing it correctly until I hit the keeper hard enough to break the air seal and push the valve into the top of the piston. I had my compressor at 110 pounds so air pressure was not a problem. There was enough pressure to actually turn the crank. I think I heard air leaking away though the manifold, so maybe I was not doing it correctly.
When I have more time I am going to do it with the rope as doing it with the air keeper valve seems a real "hit or miss" affair.
My question is is the valve stem shield suppose to ride up and down on the shaft or is it suppose to remain seated while the valve stem travels through it? The flexible rubber ones from Autozone just did not seem to do the job.
Old May 12, 2003 | 01:43 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Those OEM "seals" are really just umbrellas to keep the oil from dripping directly onto the stem and down the guide. They usually just go up and down with the valve. They are no good if oil is pooling on top of the head and running down the guides.
I have "positive-seal" valve stem seals on mine. They are a real rubber seal held in place by a metal ring. Of course, it's a good idea to use these with bronze guides because if you use them with iron, NO oil gets down there and you wear out the guide real fast.
ak
Old May 15, 2003 | 12:20 PM
rebocardo's Avatar
rebocardo
Thanks krewat!
Zorfox
Jan 8, 2012 03:46 PM
safetysandy2
Apr 20, 2010 03:24 PM
CheaperJeeper
Mar 9, 2008 01:47 PM
rwjr
Aug 14, 2001 08:51 AM
cntdew
May 27, 2001 11:37 AM
