ARP Head studs
Old Jul 29, 2012 | 09:27 PM
joeyd61's Avatar
joeyd61
ARP Head studs
we have the passenger side head off my truck,and i have been researching the studs.I have read a lot of post where the ARP's are installed with the head on.That is not possible with the set I have??The studs have a rise where they meet the block..Does ARP make this type??I am wondering if I even have ARPs..
Old Jul 29, 2012 | 10:08 PM
BigAlsPSD's Avatar
BigAlsPSD
Installed with the heads on, but you either have to raise the cab, or loosen the motor mounts and rock the motor. When you say rise, are you talking like a raised ridge? The ARP's I have seen are blank(unthreaded) in the center.
Old Jul 29, 2012 | 10:13 PM
joeyd61's Avatar
joeyd61
The best way to discribe it, Its like they have a stop where they screw into the heads..they are blank in the center..
Old Jul 29, 2012 | 10:39 PM
BigAlsPSD's Avatar
BigAlsPSD
If that is too large to fit through from the top, how will the head fit back over it when you put the head back on?
Old Jul 30, 2012 | 12:54 AM
BlueScab's Avatar
BlueScab
Not sure if this will help any but here is a pic of an ARP stud straight out of the box.
Old Jul 30, 2012 | 07:20 AM
joeyd61's Avatar
joeyd61
Alan, My main concern is are they ARP or not..This is the second time I have blown the head gasket
Brandon, Thanks..mine doesnt look like that..I have a shop working on it and I will try to get over there and get a picture of mine before they get it back together
Old Jul 30, 2012 | 07:49 AM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
so do you think you dont have arp's? is that the question here? where did you buy yours from? i didnt have a lip on mine....also how long are you letting the head gaskets season before you crank up the power and go all out on them?
Old Jul 30, 2012 | 10:08 AM
joeyd61's Avatar
joeyd61
Yes, that is what I am wondering..The engine builder installed them,I advised him I wanted ARP,my invoice says ARP..SO, I am wondering if they are not, what else is not what I asked for..
sa far as letting the gasket season, roughly 500 miles..
Old Jul 30, 2012 | 10:21 AM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Originally Posted by joeyd61
as far as letting the gasket season, roughly 500 miles..
Hey Joey, Might be worth while to retorque the heads after the 500 mi.
Old Jul 30, 2012 | 10:31 AM
joeyd61's Avatar
joeyd61
Originally Posted by Deluxe06
Hey Joey, Might be worth while to retoque the heads after the 500 mi.
Richard
I believe this time we are going to do a hot torque..let the motor heat up to running temps a couple times,then re torque while at temp..
Old Jul 30, 2012 | 10:39 AM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Sounds like a good plan.
fordf3502007
Apr 12, 2008 02:29 AM
wiccantoy
Mar 29, 2008 07:34 PM
bcford6.9
Apr 19, 2006 10:04 PM
4x4akvan
Jan 20, 2003 10:13 PM
