P0299 code?
Old Jul 29, 2012 | 09:25 PM
yankesfn2's Avatar
yankesfn2
P0299 code?
As I was towing my camper this weekend, I found that when I needed to get that extra bit of passing power, I couldn't. My superchip gave me a p0299 code. I talked to the dealer and they recommended that I have the turbo cleaned and have the senser replaced. I'm not very knowledgable on diesel engines, but I'm very capable of repairing things myself. I'm curious as to what some of you guys think may be the problem.
I have disconnected the Egr.
I have a Superchip Programmer.
Seems to have good power when camper is disconnected
Old Jul 29, 2012 | 11:28 PM
berick's Avatar
berick
One of many helpful videos on youtube for this particular problem;
P0299 lack of power and turbo sticking on a 6.0 Powerstroke F250 diesel - YouTube
Old Jul 29, 2012 | 11:37 PM
BLADE35's Avatar
BLADE35
If you going to Play you need a ScanGaugeII MINIMUM so you can check the sensors
SGII will show BOOST psi so we can tell if its Over/Under BOOSTING
Plug the EGR Valve back in it can mees with the Fan for cooling either Deleate the EGR Cooler or Run it and any way you look at it Keep the EGR Valve installed to keep FAN & PCM Happey EVEN with a EGR Cooler Deleate
EMC V10 X
Nov 19, 2014 05:19 PM
TruckingBill
Aug 31, 2014 02:55 PM
fordf150guy
Dec 31, 2013 12:43 PM
jp45601
Mar 7, 2012 08:48 PM
LSAtexan4x4
Jan 7, 2012 10:42 AM
