engine stumbling
Old Jul 29, 2012 | 11:08 AM
rockman51's Avatar
rockman51
I have an 03 F250, 6.0. Engine stumbles while under a load. Seems like overdrive only. Other than that, runs greats. According to PCM the engine and transmission runs greats, no codes. This has been going on for over a year, continually getting worse. If anyone else has this problem, PLEASE HELP!
Just changed the filter and I change the oil every 3000 miles. I use top of the line injector cleaner at least ever 8 or 10 tanks. Have already replaced crank sensor, EGR valve, which is the only codes that have ever come up in the two years that I have been driving this truck. This problem of cutting out has been going on for over a year. No one can seem to figure it out!
Old Jul 29, 2012 | 06:12 PM
Maxium4x4's Avatar
Maxium4x4
Under excelleration, stumbles, check EGR. Sounds like the unison ring could be sticking, what is the boost doing?
Brian460
Aug 16, 2011 02:44 AM
fordlowrider1979
6.4L Power Stroke Diesel
Feb 24, 2011 11:03 AM
jet5545
Jun 12, 2009 01:27 PM
robertsonthego
Oct 4, 2002 08:17 AM
