I have an 03 F250, 6.0. Engine stumbles while under a load. Seems like overdrive only. Other than that, runs greats. According to PCM the engine and transmission runs greats, no codes. This has been going on for over a year, continually getting worse. If anyone else has this problem, PLEASE HELP!
Just changed the filter and I change the oil every 3000 miles. I use top of the line injector cleaner at least ever 8 or 10 tanks. Have already replaced crank sensor, EGR valve, which is the only codes that have ever come up in the two years that I have been driving this truck. This problem of cutting out has been going on for over a year. No one can seem to figure it out!
Reason: merged (Max)
