Rear Differential Questions (Diff Cover Off)
Old Jul 30, 2012 | 11:32 AM
djed's Avatar
djed
Jim,
Thank you!!! You are correct.
I called Mobil and they explained that the 140 is a heavier oil and should not be used as a substitute so it looks like I am draining the 140 later today. Ouch - another expensive life lesson.
I also called Dana-Spicer and they (1) verified the the 75-90 is the correct weight oil, (2) they recommended a synthetic oil, (3) recommnded NOTWITHSTANDING THE ADDITIVES ON THE BOTTLE that their testing showed that the friction modifier is necessary even if the bottle indicated the friction modifier was added.
Dana-Spicer customer service also noted that a proper fluid change should include jacking up the car from each side (one at a time) so that fluid flows into the axle bearings.
Thanks again.
David
Old Jul 30, 2012 | 12:33 PM
stinson 108-1's Avatar
stinson 108-1
stinson 108-1
Cool, Glad you verified that. I remembered the weight from the last time I did mine.
Old Apr 5, 2020 | 10:58 PM
djed's Avatar
djed
Reviving a very old thread I started back in 2012, I have a Dana 80 on a 2001 DRW cab and chassis truck. I just referred back to the owners manual and it says the Dana 80 uses 4 liters of 75-140 Synthetic fluid. After calling Mobil and Dana-Spicer, I concluded back in 2012 that I should use 75-90. I haven't had any trouble in the last eight years but I don't put a lot of miles on the truck (maybe 20K - 30K in eight years).
Any new thoughts on the proper weight gear oil?
Thanks!!
Old Apr 6, 2020 | 12:51 PM
FordTruckNoob's Avatar
FordTruckNoob
Here are the specs.
Old Apr 6, 2020 | 03:25 PM
Bonanza35's Avatar
Bonanza35
You would be fine with the 75-140 synthetic. That's what I use with 80K on it now and it works fine. I have the Dana 80 DRW and that is what my manuel said to use. I used Amsoil but did have to add fiction modifier later. Now the front is different. But I bet it would work there to. And I tow a fifth wheel to boot.
Fyrfyghtr
Sep 5, 2016 05:08 PM
Mtnplow
Jul 26, 2011 07:29 AM
gene17847
Sep 3, 2010 04:16 PM
ampslw
Jan 14, 2010 12:05 PM
