need help very confused
Old Jul 28, 2012 | 04:19 PM
cyber.tripp's Avatar
cyber.tripp
the truck:
05
f250
6.0 diesel
new bulletproof oil cooler
bulletproof water pump
the problem:
finished up installing the new oil cooler primed the system. went to go and start the truck and nothing. the truck would crank over for a time then i when checked the ficm. it red 47.3 volts checked the wiring and plugs they where all in there tight and secured. went back to try and start it and got a serge and gages started to shake..i had this problem when my driver side battery terminal broke. tested connections and got 12v.
the codes:
p1378
p0611
p0113
any help would be wonderful
Thanks
mike
Old Jul 28, 2012 | 08:32 PM
cyber.tripp
no ideas??
Old Jul 28, 2012 | 09:39 PM
TrdLtly's Avatar
TrdLtly
TreadLightly
You might try posting and/or searching in the 6.0L forum: 6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Old Jul 28, 2012 | 09:49 PM
2006lariat's Avatar
2006lariat
Batteries sound like they may be dead. You say 12vlts, but that could be a "Ghost" charge. (The only way to truly tell would be a load test on each individual batt) As soon as you turn the key, the glow plugs are taking what power the batteries have left. Try charging them. If you had the oil system drained, it will take some cranking to get going. 47vlts isn't great on the FICM, but if your batts are dying it might be that.
Old Jul 29, 2012 | 01:18 PM
cyber.tripp
ok im going to try that and ill see if i cant get them on a charger sometime to day thanks for the help
Old Jul 29, 2012 | 01:40 PM
Tom's Avatar
Tom
Moved to the 6.0L forum!
Old Jul 29, 2012 | 01:50 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
The P0611 code is usually a death sentence for the FICM
Old Jul 29, 2012 | 01:54 PM
brickie's Avatar
brickie
You have 2 FICM codes,is the ground secure on the FICM?
Old Jul 29, 2012 | 01:56 PM
BLADE35's Avatar
BLADE35
AGREED^^^^^^^^^^^^
Better have it all Tested BATTERYS AND ALTERNATOR
Its already to late for the FICM
Send FICM here
www.ficmrepair.com
Nevadahunter1
Mar 20, 2017 06:39 PM
stanley6.0
Sep 19, 2016 11:51 AM
cyber.tripp
Aug 18, 2012 04:47 PM
dbarnett42
Sep 15, 2011 05:32 AM
dyhrdford
Dec 4, 2009 05:03 PM
