IDLE
Old Jul 28, 2012 | 11:48 AM
  #46
ctubutis's Avatar
ctubutis
Originally Posted by RAY1986F150
I didn't have this problem until I put in a new battery and got my a/c working.
I would disconnect the AC - un-do your changes - and see if the problems disappear.
Old Jul 28, 2012 | 12:57 PM
  #47
Dave804's Avatar
Dave804
If it's an air-through bypass IAC:
Small formed tubing to each side of the throttle. Inside is a valve similar to the piston in a rotary engine. No power is closed, max power is full open. Varies how open it is based on cooling temp, AC, etc etc.
That's what I think is sticking. Especially if the PO of the truck drove it with the AC off most often it makes sense it'd wear out or gum up at that position.
Old Jul 28, 2012 | 03:58 PM
  #48
ctubutis's Avatar
ctubutis
Yeah, it could be. But it still bugs me that this problem came up after "fixing" the AC. There are diagnostics in the book for symptoms of
Lack of fast idle assist with AC on
A/C does not cut-off under WOT conditions
Surges with A/C on at idle
But none of those match his symptoms.
But seeing those got me to thinking... this problem began when the A/C was serviced, the cause of the problem likely originates there, then.
Old Jul 28, 2012 | 04:10 PM
  #49
RAY1986F150's Avatar
RAY1986F150
Wow, looks like I missed alot of conversation. The truck actually did well today. Idled just fine, no surging or stalling.
I went over to Gary Lewis's today and we installed new axle pivot bushings. One of mine had no rubber left!!! Holy moly. We had a bit of a time installing the first one, but got it figured out and the second one slide right in after heating up the I-beam and using a installing Gary fashioned up.
As for the idle, last night I unhooked the IAC. Then got the truck running without the IAC. Then gradually adjusted the idle screw until the engine would just barely run then die. Then I hooked the IAC back up and let the battery sit unhooked for awhile. Hooked it back up and let the computer do its thing for a couple minutes, then went for a small cruise. It seemed to be doing okay.
The only thing i still notice is when starting cold it fires up, gets sort of close to dieing, then revs up good and slowly comes to a good idle.
easyridin
Nov 16, 2015 05:20 PM
cryptyx
Sep 29, 2014 08:27 AM
jim2029
Sep 8, 2008 09:01 PM
Aggie05
1983 - 2012 Ranger & B-Series
May 28, 2008 05:50 PM
nelly781
1978 - 1996 Big Bronco
Oct 15, 2003 02:43 PM
