Cuise control install question....
Old May 11, 2003 | 11:40 AM
randemart's Avatar
randemart
Hi, I'm new to your forum. Looks like a great source of information.
I have just been issued a 2000 Ford Ranger for work & would like to install an AudioVox CCS-100 aftermarket cruise control. The sheet that comes with it listing vehicles with VSS doesn't include Rangers past the year 1995. I would hope this is just an outdated list, & that the 2000 models would have it, eliminating the need for magnet sensor installation.
Any help is much appreciated.
Ray
Old May 11, 2003 | 01:38 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
The VSS is located on the rear.
Old May 11, 2003 | 04:41 PM
Rockledge's Avatar
Rockledge
Question Cuise control install question....
Ken, do the 98+ Rangers have a VSS? I thought they picked up the speed signal through the RABS system somehow.
Old May 11, 2003 | 07:22 PM
Ken00's Avatar
Ken00
The RABS uses a VSS on the rear to determine speed, 4wABS might be different for speed but I believe they still have a speed sensor on the rear for the RABS. If someone needs to know for sure I'll craw under our 2002 and look.
Old May 11, 2003 | 08:42 PM
Hank85713's Avatar
Hank85713
instead of cutting the wires to install I used the magnets! You can get some 5 min epoxy to hold them with.
Old May 11, 2003 | 10:30 PM
randemart's Avatar
randemart
Thanks for the replys.
FYI, here's an excerpt from a page I found on "the12volt.com" website.
Hank...is the operation just as good using the magnets?
00 FORD RANGER
CRUISE CONTROL
Part # 250-1176
Part # 250-1223
Control Lever: 250-3421,250-3125,250-3742
Adapter: 250-3417
VSS Wire: LOCATION 12- POSITION 58 OF 104 PIN CONNECTOR OF PCM
VSS Wire Color: GRAY/BLACK
VSS Pulse: 8000
VSS Tach Wire: LOCATION 12- POSITION 48 OF 104 PIN CONNECTOR OF PCM
Tach Signal Wire Color: TAN/YELLOW
Brake Switch Positive: LIGHT GREEN/RED
Brake Switch Negative: LIGHT GREEN
Old May 12, 2003 | 10:49 AM
Hank85713's Avatar
Hank85713
I probably have about 10K on it since I hooked it up and they have not caused any problems. Its basically the same setup as they used to be from the 70-80's when that was all that they offered.
Their (audio-vox) customer support is pretty good as I had several questions during the install.
forget what year ya have but I installed the butons up under the light switch on the dash (94 model). Had to drill a hole in the panel and put double stick tape to hold it. Also the real problem I had was that the black wire on the switch needs to be grounded and I don't think that was real clear in the instructions.
Old May 12, 2003 | 01:23 PM
randemart's Avatar
randemart
Thanks for the advice, Hank!!
