Oil & Lubrication
5w-20 Syntec Blend
Old May 11, 2003 | 09:23 AM
pelletier20's Avatar
pelletier20
5w-20 Syntec Blend
Has anyone compared Castrol Syntec Blend 5w-20 with Motorcraft 5w-20? Also how does Castrol GTX 5w-20 stand up to the Motorcraft 5w-20?
Old May 12, 2003 | 02:11 PM
Flash's Avatar
Flash
5w-20 Syntec Blend
Syntec is a Group III basestock with about 50 ppm's of moly. The 5w-20 GTX is a blend of Gp III and Gp II+ with about 50 ppm's of moly. Motorcraft does not have the moly but is similiar in basestock with the GTX. Moly only comes into play in EXTREME heat situations when the boundary lubrication is all the protection you have left. Most vehicles will never see this situation. Considering the oils must pass the Sequence IIIF standard, there isn't much room for improvement. Any of the three offers more benefits than a normal Xw-30. Cleaner engine, less deposits, better fuel mileage, higher Viscosity Index , lower oxidation, and less thermal breakdown.
Old May 14, 2003 | 10:32 PM
mikemc's Avatar
mikemc
5w-20 Syntec Blend
I am using 5w20 in my '02 Ranger while its under warranty. I decided to use the Castrol GTX as it meets the Ford spec, is easy to find and has some moly. I catch it on sale at Advance for $1.38/qt. and stock up. I feel it will do fine.
meborder
May 7, 2015 09:50 AM
claycomotrucks1991
Oil & Lubrication
Aug 13, 2014 08:35 PM
RobbyMartin
1997 - 2003 F150
30
Oct 2, 2010 06:35 AM
dirtmonkey11
43
May 20, 2010 12:34 PM
bill11012
Modular V10 (6.8l)
20
Nov 25, 2009 06:14 PM
