2000 Ranger automatic transmission problem
Old Jul 24, 2012 | 01:46 PM
hamjr1943's Avatar
hamjr1943
I have a 2000 ranger 3.0,automatic 4x4.The truck will not go forward in drive 1 or in drive.If I start out in second gear it will shift through the other gears.Does anybody know what the problem is?
Old Jul 24, 2012 | 03:06 PM
Fordtech2199's Avatar
Fordtech2199
Possibly a clutch
Sounds like could be a bad clutch pack.
Did this start all of a sudden, has it been slipping, how is your trans fluid level? Does the fluid smell burnt and have a brownish color to it? It should be red in color and smell like oil. How many miles on your truck and when was the last trans fluid/filter change done?
Old Jul 24, 2012 | 04:27 PM
hamjr1943's Avatar
hamjr1943
The truck wasn't running when I bought it (bad starter)but I knew it might have an engine or transmission problem.The fluid is where it should be and is bright red and does not smell like it is burned.
Old Jul 24, 2012 | 05:00 PM
Fordtech2199
At this point I would suggest you have a transmission shop diagnose the problem for you. It could be a blocked passage or stuck piston on the low band, or as mentioned a bad clutch pack.
Need to get the system pressure tested.
Old Jul 24, 2012 | 09:57 PM
g_k50's Avatar
g_k50
Insure that the problem is not just the shift lever indicator on the steering column being out of adjustment.
Old Mar 15, 2015 | 08:09 PM
Kevin LaRoux's Avatar
Kevin LaRoux
2000 ranger trans not working
I picked up a 2000 ranger 4.0 auto 4x4 a few weeks ago and the transmission stopped working. It goes into every gear easy but won't move? What could this be? I've been told the valve body gaskets? Any help would be great. Thanks!
Old Mar 16, 2015 | 10:05 AM
f5fordgirl's Avatar
f5fordgirl
Could be the torque converter, pump, or linkage inside broke or fell off.
jcw819
Mar 24, 2011 10:59 AM
twostroker
Sep 17, 2009 04:51 PM
ziggy9mm
Nov 27, 2007 01:34 PM
Lykos
Jan 12, 2006 07:45 PM
filpit58
Sep 20, 2004 07:49 PM
