Patch Panels
Old Jul 23, 2012 | 11:03 PM
belk42's Avatar
belk42
Patch Panels
Ok, so i'm sure that there are alot of people who want to know this question......who has the best patch panels for our ol dents????? AND BEGIN.......
Old Jul 23, 2012 | 11:41 PM
HIO Silver's Avatar
HIO Silver
I assume you mean body panels.
Nothing beats OEM but i would have no issue using panels from LMC, NPD, BOTP, or DC. Caveat... I used a repro wheel arch from NPD and the fender lip wasn't as crisp as the original. Unless you have a keen eye, ya can't really tell cuz it is impossible to view both bed sides at the same time.
$0.05 ("That's my nickel on this subject")
Old Jul 24, 2012 | 12:47 AM
seththomas85's Avatar
seththomas85
if you are on a budget like me ive got all my stuff thru LMC and NPD. The body shop that does my work has never turned them down.
Old Jul 24, 2012 | 01:15 AM
hasteranger's Avatar
hasteranger
I bought 2 cab corners by accident from jeff's bronco graveyard in the same order. One was thin sheet metal that had crimped corners (they had flats then sharp angles like an octagon instead of like a circle) and didn't fit very well, had a sort of flare where the corner was. The other one was thick sheet metal, no crimps, smooth bends, and sat down just like the original. so idk, I can't just say something like "order one from jeff's bronco graveyard" because I don't know which one you would get. But apparently there are clearly difference between the different brands. If its not a show truck, any of them will work, but some of them will require more work to fit in a manner closely resembling stock.
Old Jul 24, 2012 | 12:14 PM
montana_highboy's Avatar
montana_highboy
Old Jul 24, 2012 | 04:13 PM
ChaseTruck754's Avatar
ChaseTruck754
good Lord - after seeing what they charge for parts I should up what I ask when I part trucks out! They want $230 for the 460 motors towers I sold for $40 and $130 for the cab mount towers I sell for $40.
And I love how they say "made in the USA" - that's because they're cutting it off the original trucks. They should say "made in USA or Canada" due to that!
Old Jul 24, 2012 | 04:43 PM
hasteranger
a lot of their stuff is used, but some of it looks like new sheet metal. Really, in the pics of the new stuff, most of it looks very similar in thickness and quality to the overseas **** that I've seen.
Old Jul 24, 2012 | 04:59 PM
montana_highboy
Personally i can only speak to the floor pans and cab mounts, as those are my only purchases of the very same item with two different vendors.
I can assure you the pans and mounts from 'F100' are much thicker than those of LMC, while i didn't throw a mic on them it was pretty obvious to the naked eye that they were a much heavier gauge material.
Old Jul 24, 2012 | 10:18 PM
hasteranger
Well, like I said, I ordered 2 of the same thing from the same vendor and got 2 panels of vastly different quality. Both were imported. So they may be thicker than one but not another.
LadderDogV10
Jul 11, 2017 07:24 AM
fiftyfordfloored
1978 - 1996 Big Bronco
Oct 11, 2016 12:52 PM
TxStang2010
Feb 24, 2014 08:04 PM
zottyzot
Nov 22, 2011 02:39 PM
LARIAT 85
Paint & Bodywork
Mar 12, 2010 09:21 PM
