HELP!
Old Aug 22, 2012 | 08:34 PM
oldbird1965's Avatar
oldbird1965
You might not be 'being silly' Arron!
Old Aug 22, 2012 | 09:31 PM
Action4478's Avatar
Action4478
Glenn is right , I wouldn't dismiss that yet ...
Old Aug 23, 2012 | 07:51 PM
bubba_3711's Avatar
bubba_3711
im about to give up and just take it to a mechanic for the first time in my life = (
Old Aug 23, 2012 | 08:32 PM
fordman67's Avatar
fordman67
Did you check the hpop resivour level after letting it sit all night? How long since oil change? Condition of lube oil pump can affect oil level for hpop adversely until engine is warm.....rick...am I learning now?
Old Aug 23, 2012 | 08:34 PM
fordman67's Avatar
fordman67
Lube pump is behind balancer on the outside of timing cover. .003 recession of gears is max wear.also check timing cover for wear.
Old Aug 23, 2012 | 10:17 PM
bubba_3711's Avatar
bubba_3711
its been sitting for about a month now, i tryed starting it yesterday and would not start at all. i even used a tiny shot of either. oil has around 2000, 2500 miles on it. did not check level of hpop because it is striped out where you put the key stock in. going to work on it this weekend. and get the hpop plug out and get a new one thats not striped out. a friend said possably the idm was bad, what do you think?
Old Aug 23, 2012 | 11:21 PM
fordman67's Avatar
fordman67
It only idles when cold...runs fine once hot...man I may be off base but I really am leaning toards an oil issue. Lord knows I aint perfect but I would be checking some things before I pay someone to guess.BUT if you have an idm you can borrow...try it for it is less work to swap...
Old Aug 23, 2012 | 11:24 PM
fordman67's Avatar
fordman67
or if you have a scanner you can also watch icp vs ipr values and see if the pressure is low also.500 minimum to start. less than 16% duty cycle at idle If I remember corectly.
Old Aug 23, 2012 | 11:28 PM
fordman67's Avatar
fordman67
I know I wont ever didmiss that again...
Hamberger
Feb 15, 2007 11:15 AM
catalina66
Aug 17, 2006 12:52 PM
blessteve
Feb 18, 2006 02:40 PM
neoflee
Nov 6, 2005 10:02 PM
griswold
Mar 11, 2005 04:22 PM
