i've not compared my van to a pickup, but i have to say that with all due respect to the c6, 3.55 gears and current weight of 8000, she has quite a bit of power. i haven't actually checked my 0-60 time or been to a dyno, but i'm as satisifed as i can be until/unless i decide to drop $3k on a turbo kit, which isn't likely to happen any time soon.
and i don't know what plumbing problems would actually cause a loss of power. the water seperator was placed along the frame rail (i hear its up on the firewall in pickups), the air cleaner sits not more than an inch from the body, but appears the same as those found in pickups, the exhaust doesn't look cramped... so i don't know what disadvantage it would have.
and i get 15MPG, which is absolutely unheard of on a gasser of this weight
The diesel vans have no less power than trucks. Some things on the engine are in different positions, and some things are different, like the drivers side exhaust manifold, and the oil cooler.
The fuel filter head is on the drivers side, rather than on the passenger side like in trucks.
Both vans and trucks have same power. I don't know who told you that the van engines have less power due to being stuffed in a van, but hes sadly wrong.
Yeah indeed. I loved the IDIs. When I was in the car business in the late 80s and early 90s, we had a contract with a large construction company that only bought F-350 crew cab 4WD trucks. All of them were dark blue 7.3 trucks and all had manual transmissions. They were HUGE for the time but those were great trucks.
Do the 4x4 conversion and use the 460 or a Windsor.My E150 weighs about 5600 lbs empty(has two captains seats and carpeted rear).With a aluminum headed 351 and 3:50 gears it gets about 13mpg in the mountains.It also passes emissions here on the left coast.I doubt you'll get much better mileage with a smaller engine as less cubes will work harder to move that mass.
