New Lights
Old Jul 23, 2012 | 06:57 PM
PITS's Avatar
PITS
Originally Posted by biz4two
WOW! How...???
Would like to see a day picture of how you did that??? Again...WOW!
biz
When I installed it:
Originally Posted by Tuxedo Scorpion
id be more interesting in the beam pattern than looking at the vehicle
With the headlights on against the garage door:
Old Jul 24, 2012 | 11:07 AM
W7PSK's Avatar
W7PSK
Veteran: Navy
Originally Posted by AzBlueOval
I also put on the cab lights myself. A
How was it to do that? I wish I had that option, but the dealer wanted 550 to do it. Im really nervous getting a drill near the truck. But I really would like cab lights.
Old Jul 24, 2012 | 12:06 PM
AzBlueOval's Avatar
AzBlueOval
I ordered the lights and wiring harness from a Ford dealer and the install was nerve racking at first, after all you are drilling 15 holes in the roof of a new truck. I read up on what everyone else tried and recommended and had it done in about 3-4 hours. Hardest part was finding center. It was worth it, I've always liked cab lights.
Old Jul 24, 2012 | 12:59 PM
bigtwinharley's Avatar
bigtwinharley
Where did you Tie into the head light switch at. About to order the same thing you did but with the chrome bracket
Thanks
Tom
Old Jul 24, 2012 | 03:19 PM
AzBlueOval's Avatar
AzBlueOval
Thanks
Tom
I popped off the light switch and used a test light to see which wire on the back side was hot and when. Doing that, I was able to find the wire. I might go back in and change it up because the one I found, the three grill lights don't come on when I unlock the truck, but they do come on with the switch when I put it in parking lights and on auto. I might just leave it anyways. I think it was one of the top row of wires, furthest from the drivers door, if that makes sense.
Old Jul 24, 2012 | 11:04 PM
majkthreads's Avatar
majkthreads
How did you fit your light bar in the grill? I ended up attaching it to the push bar.
Is your's a driving beam pattern, flood or spot?
Old Jul 26, 2012 | 01:04 AM
PITS's Avatar
PITS
I hung it right off that pipe in front of the radiator as you see. Used hose clamps where those zip ties are. Also added some additional support to that pipe.
Mine was the "spot" pattern but the "Elite" model that he sells has little lenses in front of each LED to greatly enhance the spot effect. I like mine kind of in between a spot and flood as I need a wider and not longer throw.
It is scary bright.
Old Jul 31, 2012 | 10:19 AM
bigtwinharley
I got all parts from etrailer. I went and got three of these Sealed, Miro-Flex, Mini Thin Line, LED Marker, Clearance or ID Light, 3 Diode - Amber Optronics Trailer Lights AL191CAB. They are clear trailer marker lights with amber LED's. What's nice is during the day, they look like the grill, almost same width and everything.
On the bottom of the page I also got 3 black plastic mount brackets and 3 two wire pigtails for the above lights. I went with the 18" pigtails, glad I did. Then I went to Lowes and found some metal brackets about 2" x 8" and cut them to about 4" or so. These brackets go behind the grill and the black plastic mount brackets go in front and they bolt together.The pigtails just snap into the lights and lights snap into the brackets. I ran all the positive wires together and tapped into the headlight switch. The other wire is the ground.
I thought about hooking these into an up lifter switch, but decided to go this route instead.
Original thread can be found here
LED clearance grill lights (Raptor Look) - Ford Powerstroke Diesel Forum
AzBlueOval
Question for you I just got my lights deliver and was ready to install question I have does the pig tail hit your plastic fins on the grill. Looks like mind will rest or touch on the fins
Please let me know I have the front grill off now LOL.
Old Aug 1, 2012 | 12:23 AM
AzBlueOval's Avatar
AzBlueOval
AzBlueOval
Yea, I had to shave mine down a bit to fit in between the grill. I used a dremel tool and shaved the black pig tail down pretty close to the wire. Forgot to mention that earlier. Good luck. Make sure to add pics when done.
ForgottenFate
Aftermarket Products
15
Jun 2, 2016 12:44 AM
Vegetable0
Feb 12, 2016 07:28 AM
awq134
2009 - 2014 F150
Mar 26, 2013 01:16 PM
TireJockey
57
Jan 4, 2013 09:59 PM
LSchicago2
Apr 8, 2011 09:53 AM
