Bed Rust
Old Jul 20, 2012 | 10:03 PM
85blackbeauty's Avatar
85blackbeauty
Bed Rust
OK here is another question to all you who have tackled a restoration on these trucks. My truck has developed rust over the rear fender wells, and it is pretty severe at least in my opinion. Would it be better to try and find a whole bed that is relatively rust free, or use patch panels? I can weld, but have never welded sheet metal. My truck is black, so it will make a crappy job really apparent. My front fenders also are developing bubbles on the bottom behind the wheel well. New fenders or again, patch them? My plans for the truck is not for it to be totally perfect, and I will be keeping the truck from now on, so I want the best job I can do. Thank you all for your help.
Old Jul 20, 2012 | 11:54 PM
86fordtruck's Avatar
86fordtruck
I would go with patch panels, because a rust free bed is going to be difficult to find and probably not cheap. There is an excellent welding tutorial over in the 48-56 Forum by AXRacer at:
https://www.ford-trucks.com/forums/1...-practice.html
For the most part it is getting the panel cut to size, and then stitch welding it in, and grinding the welds flat. Heat control is key so you don't warp the panels.
Get a couple pieces of sheet metal about the same thickness as your patch panel, and practice stitching them together, then go to work for real. Take your time, spread the tacks out and work slowly. Control the heat when grinding down the tacks, as well, taking your time and not staying in one place for very long. Then a bit of body filler, guide coat and a long board should allow you to get a really good looking job even with a black truck. Good luck.
Old Jul 21, 2012 | 01:43 AM
JayzDaddy's Avatar
JayzDaddy
Lmc truck selld fenders for about 100 bucks. Entire bedside panels are 400 with entire bedside skins being 240.
Old Jul 21, 2012 | 03:04 AM
jerd_hambone's Avatar
jerd_hambone
Yep, patching isn't a godawfully difficult task. But it's VERY easy to get just a bit too hot and warp the metal.
I'd say that patching would be best because finding rust free beds for these trucks is almost impossible. As for fenders, I'd say you could find some in good shape that may need some slight massaging.
Old Jul 21, 2012 | 06:55 AM
Franklin2's Avatar
Franklin2
It depends on where you live sometimes as far as availability of a good used bed, so I would at least check around for a good used bed first.
If you patch yours, make sure you look at the rear lower corners of the bed, there is a brace there that likes to collect dirt and they rust out there also. You may be able to clean it out and paint it to stop it. There is another brace on the lower front corner of the rear wheel well that does the same thing, only they have to be very rusty for it to start there.
Old Jul 21, 2012 | 08:27 AM
85blackbeauty
Thanks for the advice. I may be going with the patch panels after all. I live around Louisville KY, and every time it rains in the winter it seems they roll out the salt and brine trucks, so most of our model trucks have that rot above the fender wells. I guess I can use my truck as a learning experience, because it will be driven daily in all weather, so it doesnt have to be concours perfect. Just want her to look nice and preserve it for the coming years.
Old Jul 21, 2012 | 11:02 AM
jerd_hambone
Another Kentuckian! Yep. Good luck finding a good bed haha. I have the cleanest bed I've seen in my area. And there are a LOT of bullnose trucks here.
I have slight rust are the fender wells and that's it. Bed floor is solid. I think I got lucky though.
Old Jul 21, 2012 | 11:46 AM
JayzDaddy's Avatar
JayzDaddy
Seriously order a catalog from LMCtruck.com. its free and has about everything but a frame and cab in it. Off hand i could redo almost my entire body for around 1600 bucks. You may could piece other places together for the same or cheaper but its a great info source.
Old Jul 21, 2012 | 06:59 PM
FordFETruck's Avatar
FordFETruck
I've got a rust free 86 8ft bed, but it's attached to my truck lol
Old Jul 21, 2012 | 07:21 PM
investedocean's Avatar
investedocean
I have seen a couple decent ones down at the local pick-n-pulls here in TN. They typically run 200 bucks. The fenders are easy to find in decent shape and they cost 40 bucks. I had to find a set of them and doors recently.
Old Jul 21, 2012 | 08:10 PM
Diesel_Brad's Avatar
Diesel_Brad
I would get a GOOD use set of fenders(not worth patching a $50 fender)
For the bed, GET BED SKINS. They can be changed in a weekend, are alot less work than a patch panel and it will be fixed RIGHT
Old Jul 22, 2012 | 04:43 PM
Yaga1973's Avatar
Yaga1973
Elder User - What???
Excellent advice!
diggerrigger
Nov 2, 2017 04:49 PM
TractorMaster96
13
Jan 27, 2013 06:57 PM
DCFord
Paint & Bodywork
20
Nov 24, 2007 05:29 PM
twisted
Paint & Bodywork
Aug 19, 2005 11:14 PM
frederic
Apr 15, 2005 09:53 PM
