A/C service ports
Old May 10, 2003 | 06:45 PM
Rtpjunior's Avatar
Rtpjunior
A/C service ports
It is getting close to summer, and I'd like to charge my A/C system. The only problem is that I can't find the low (suction) pressure port. The High pressure port is right next to the battery, but I can't seem to find the other one. I have rear A/C in my truck, so I wonder if it is located in the back. Does anyone have any info on this ? Also, are there 2 separate systems, or do they feed of the same refrigerant lines ??
Old May 10, 2003 | 10:28 PM
buzzard's Avatar
buzzard
A/C service ports
The valve you are looking for is very hard to find. Without having my hood up right now and going from memory, it is tucked back up nearer the cab in a direct line from the valve you can see. Just follow the lines toward the cab and you will feel the cap. Unscrew and then have fun getting the hose attached....watch those knuckles. Leave it to Ford to make it nearly impossible to charge the AC. It is basically one system with only one "charge" point.
Ed Allen
Jul 30, 2012 06:39 PM
rooster22
Aug 29, 2010 09:04 AM
firepop5
Jun 21, 2009 02:47 PM
dtharrett
1997 - 2003 F150
17
Jul 26, 2005 07:58 PM
Nvr Fnsh
Jul 21, 2005 05:32 PM
