Soft Brake Pedal
Old Jul 20, 2012 | 08:32 AM
84-6.9L's Avatar
84-6.9L
Soft Brake Pedal
I figured Id share some information with the group and hopefully help solve somebodys issue someday.
So I gave my old Kelsey-Hayes trailer brake controller its last rights yesterday, the hydraulic arm wasn't making a full sweep and the coil inside was dead. I found a nice newer one that is the same type, its another Kelsey-Hayes that taps into the brake line.
After I installed the new(er) one my brake pedal firmed up and the rear brakes work great. I think the old one was sucking air and making a squishy pedal. So I you have an old hydraulic over electric controller andyou have a soft pedal trying looking into the controller as the cause.
Old Jul 20, 2012 | 02:45 PM
joshofalltrades's Avatar
joshofalltrades
good to know! most controllers these days are all electric, but i kinda like the idea of the hydro unit, as it can sense hydraulic pressure and apply more precise braking according to what your foot is doing
Old Jul 20, 2012 | 04:28 PM
whalebus2112's Avatar
whalebus2112
If he is using hydro then he is pulling really heavy. Usually its a pretty heavy duty trailer to use hydro brakes
Old Jul 20, 2012 | 10:11 PM
joshofalltrades
whalebus, how i understood him was a hydro-controlled electric brake controller. a friend of mine has one on his 85 F250 diesel. the trailer has electric brakes, but instead of having the controller read the brake light signal it reads the fluid pressure and applies the brakes accordingly. these systems are becoming quite rare.
AFAIK, the only trailers that have hydraulic brakes are those which use surge brakes, which the basic principle is that when the tongue is under a compression force (braking, backing up hill, etc), the hitch ball pushes on the MC pushrod and applies the brakes. my car dolly has this system, and its also common on boat trailers. but this isn't the subject of this thread
Old Jul 21, 2012 | 01:27 AM
84-6.9L's Avatar
84-6.9L
Josh you are correct. I will post a picture when I get out of the hospital with my new baby girl.
Old Jul 21, 2012 | 11:58 AM
SnuffthePunkz's Avatar
SnuffthePunkz
Sorry nothing useful to add to the thread, just wanted to say congrats on the new girl!
Old Jul 21, 2012 | 02:23 PM
whalebus2112
I have surge brakes on all my boat trailers I have had but I could have sworn on some of the heavy duty trailers they had hydro brakes with out the surge system on it but I could be wrong, Its happened before
Old Jul 21, 2012 | 09:20 PM
84-6.9L's Avatar
84-6.9L
Thank you it looks like we get to go home Monday. You know you're tired when you fall asleep and almost fall out of a folding chair.
Old Jul 21, 2012 | 09:31 PM
joshofalltrades
whalebus, i've never heard of such a system and would find it quite unlikely because of the problems it would likely cause. it would be a nightmare to connect to the tow vehicle's brake system, would get an air bubble every time you connect, and would take away braking pressure from the truck's rear wheels. i suspect you may be mistaken on this one.
i've seen some pretty heavy duty surge brake systems
Old Jul 21, 2012 | 09:47 PM
tecgod13's Avatar
tecgod13
There are systems out there that have hydraulics brakes on the trailer that are electrically controlled. It entails having an electrically controlled master cylinder on the trailer that gets the signal by wire like regular electric brakes. I have no idea what types of trailers these would be on, but the system is out there (and expensive).
Old Jul 22, 2012 | 03:18 AM
Aune163rd's Avatar
Aune163rd
Well my 2 cents is this:
Well....i dont have any 2 cents....just a congrats on the baby girl!!!
Old Jul 22, 2012 | 10:19 AM
whalebus2112
Thats what I think I am thinking about.
Old Jul 22, 2012 | 06:32 PM
joshofalltrades
i guess thats possible, but i've never heard of such a system. most big-rigs use air brakes on both truck and trailer, so i never would have thought of this system.
Old Jul 22, 2012 | 10:40 PM
84-6.9L's Avatar
84-6.9L
I have seen that system on old heavy duty tag trailers ment to be pulled by trucks with juice brakes, the truck had the controller in it and sent the signal to the master cylinder on the trailer, they worked but must hhave been a nightmare to maintain especially in northern climates like here in MN. I know they do exist because I have seen several mostly on pre-70's deckovers and some of the very first gooseneck trailers
Old Jul 22, 2012 | 11:10 PM
Country_boy_2007's Avatar
Country_boy_2007
hey congrats and good luck man.
i had the same unit in my 88 till my gooseneck set it on fire...lol that was interestiog to say the least. replased it with a new Hayse controller and had the same expirence
