Sponsored by: Real Truck
Mountain Towing
Old Jul 18, 2012 | 08:21 PM
TAMac's Avatar
TAMac
Mountain Towing
Towing question - went horse-camping last week with a group, three diesel-duallys [2010 f-450, 2008 f-350 and 2006 GMC 3500] towing 3H and 4H LQ trailers from 12,000 - 14,000 lbs. There is a 9-mile portion of the trip where the road climbs approx 3,000 feet and we had long discussion about best method of towing up that grade. GMC guy swears it should be 4-wheel low; both us Ford guys left tranny in D , 2-wheel and had no problem. temp was 102 at the bottom of the grade, watched guages and saw a tad of movement but nothing even close to getting hot.
So what's the verdict out there?
Old Jul 18, 2012 | 08:57 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Four wheel low is the way to go if you're on a dirt road at low speed. Four wheel high if it is a low traction, higher speed. Two wheel high if it is a paved road at any speed.
Old Jul 18, 2012 | 09:06 PM
netaq's Avatar
netaq
What was the GM dude thinking.....4 wheel low on a highway.....sounds like a recipe for something breaking....you did it right.
Old Jul 18, 2012 | 10:59 PM
kd0axs's Avatar
kd0axs
NEVER use 4WD on dry pavement, especially 4 Low. You WILL destroy things, most likely your transfer case.
Old Jul 18, 2012 | 11:03 PM
Kajtek1's Avatar
Kajtek1
Assuming the speed was in 30-40 mph range, Low on transfer case and 4th gear on the transmission is close to 2nd gear on high. I might be a gear off, but the engine doesn't care how the final ratio is done as long as it gets its good rpm range.
4WD on dry pavement on truck with no center differential makes front axle working partly against the rear axle, as tires are never the same, so that is something I would avoid.
Old Jul 18, 2012 | 11:27 PM
kd0axs's Avatar
kd0axs
Yeah, low range on the transfer case and higher gear on the transmission could give you roughly the same final drive ratio. The bigger problem is the use of 4WD on pavement. If you had manual hubs, you could leave them unlocked which would basically give you 2wd Low. The only advantage to this would be getting the load moving from a stop, but if getting moving is that much trouble, the load is WAY too big for the truck anyway. 3000 feet rise over 9 miles means you are averaging roughly a 6% grade, which is really not that steep by mountain standards. Should be zero problem with this at all, especially with a diesel. I would be more worried about the trip back down.
Old Jul 19, 2012 | 05:44 AM
redford's Avatar
redford
FTE Leadership Emeritus
The verdict is the Chevy guy just demonstrated why he purchased a Chevy.
Old Jul 19, 2012 | 07:45 AM
GVS's Avatar
GVS
That got a laugh out of me!
Old Jul 19, 2012 | 08:35 AM
jdadamsjr's Avatar
jdadamsjr
TeeHee - me too
If it's dry - no 4x4 even if it is a straight paved road...
if it's wet, dirt, or mud, then maybe 4x4 high if slipping...
if the speeds are 25 mph or lower than maybe low range, but why ?
the stock config can pull VERY well from 0 thru 80 !!! if it has to, it will go into first gear, but let the truck's computers tell you that - that's why they call it an automatic
99% of the time I'm not even in tow haul except to slow down or coming down hills...
Old Jul 19, 2012 | 09:40 AM
HuntsDucks70's Avatar
HuntsDucks70
spot on! great points and well put
Old Jul 19, 2012 | 10:16 AM
Kajtek1's Avatar
Kajtek1
I hope newer trucks pull better on 1st gear. My 2000 with 4-speed auto is so lousy that I have to switch to low for maneuvering on my driveway. Cold engine with 1 on high will not move empty trailer even on minimal incline. My front hubs leak the vacuum, so I am not worrying about stress between the axles. I am thinking about capping off the hose and leave manual hubs only. I never need 4WD, but low gearing often is a must.
Old Jul 19, 2012 | 07:18 PM
TAMac's Avatar
TAMac
The trip down is 4WD low in 3rd gear. piece of cake, stays right around 18-20mph and tap the brakes maybe twice.
Old Jul 19, 2012 | 09:34 PM
runmountain's Avatar
runmountain
You'll know when you need low range on dry pavement. For me, it's been during steep loaded descents. I have manual hubs on my '02, and run with them disengaged (unlocked) in 4-low. Doesn't hurt anything since the front wheels freewheel.
Old Jul 20, 2012 | 09:08 AM
kd0axs's Avatar
kd0axs
Maybe I should repeat myself:
There is absolutely no reason you need to be using 4 Low. All you are doing is causing damage to your truck.
Old Jul 20, 2012 | 09:24 AM
Snowseeker's Avatar
Snowseeker
4 low is spinning a sun gear and many little gears in the transfer case making it heat up allot! 4 low should never be used for "driving anywhere". 4 low is for getting unstuck or maybe moving something heavy around the yard. There should never be any distance traveled in 4 low.
