Ignition ID
Old Jul 18, 2012 | 04:44 PM
Labhound's Avatar
Labhound
Ignition ID
I have a couple of distributors, one in a '82 and the carb has all those wires and vacuum lines all over it, the other on an '87 motor, I think it's original to the motor but, the 87 has a ford 2 brl on it.
The caps are different but they both have the wire plugs on them.
So, witch is the "good" one?
Old Jul 18, 2012 | 07:24 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Are you sure the '87 isn't fuel injected? Ford never put a 2BBL on the 300.
Old Jul 18, 2012 | 07:46 PM
Labhound's Avatar
Labhound
The block is dated E7T... the carb is on an adaptor, mechanical fuel pump so no EFI.
What's the difference between the distributors?
Old Jul 18, 2012 | 09:00 PM
BaronVonAutomatc
It's hard to say without seeing them. Do they both have a vacuum advance can?
Old Jul 21, 2012 | 01:20 PM
ctubutis's Avatar
ctubutis
Some distributors (pre-1984-85, whenever they began with the feedback carb) were for Duraspark I and Duraspark II ignition systems. Ford then went to the EEC III and EEC IV computer-controlled ignition systems, those have the ignition modules on the distributor instead of on the front wheel covering and there are no vacuum lines on them (the distributors).
California trucks had computer-operated stuff well before everybody else.
cstephens
21
Sep 20, 2015 09:38 PM
publiuss
Aug 24, 2012 01:12 AM
al ballard
Jun 29, 2008 10:09 PM
cfrives3
1978 - 1996 Big Bronco
Feb 24, 2008 04:46 PM
Bueller
Feb 20, 2005 05:59 PM
