78 engine swap
Old May 10, 2003 | 10:12 AM
jameswalk's Avatar
jameswalk
Post 78 engine swap
Im in the process of putting a 89 302 ho in my 78 f-150 was wondering if the manual fuel pump would work after swapping timing covers
Old May 10, 2003 | 11:07 AM
mudder trucker's Avatar
mudder trucker
78 engine swap
i did this swap also. it will work, but you need the fuel pump cam also. its a small piece that bolts on to the end of the camshaft. mudder trucker.
Old May 12, 2003 | 11:00 AM
loudfords's Avatar
loudfords
78 engine swap
Most EFI small blocks still had the fuel pump eccentric on the cam, even if there was no hole for the fuel pump in the timing cover.
orange78oval
1978 - 1996 Big Bronco
Mar 2, 2004 10:09 PM
masterbeavis
Nov 2, 2001 05:15 PM
karljay
Jun 15, 2001 08:23 AM
