Backup Camera Wiring
Also, if you were to count pin numbers 1-11, 1 being on left what would they be?
The white.green is to the left of the black. I dont see the tan/violet, is it hidden behind the front row?
thanks!
not shown clearing is the other half of the plug....the corresponding slots on the top half are open....that is were you would inset pins to make a connection provided you have the correct style pins to crimp onto your wires to fit the plug.
Ok for the tech data. The camera connector beneath the tail gate is C497 and is a 6 conductor cable.
Pin 1 is Violet with Gray strip and is +12 volts
Pin 2 is White with Green strip and is Video +
Pin 3 is Brown with Violet strip and is Video -
Pin 4 is Black and is a ground shield for Video. This is Not power ground and should not be used for Power Ground.
Pin 5 is Black on Male connector and Black with White stripe on Female connector and is Power Ground.
Pin 6 is not used.
Hope this helps
What I have done
Pioneer dvd/nav/radio head unit - RCA to Rear Video Input
pin 1 - Tan/Brown - 12v+
pin 2 - white/green - RCA+
pin 3 - Brown/blue (I think) - RCA-
pin 4 - Black - Not used
pin 5 - Black/White - 12v-
pin 6 - non-existent
is there something i'm missing? would it hurt the camera to switch the RCA +&- to test it as long as i don't put it to the 12v? would it hurt to ground both the black and black/white together?
When it came to the rear camera, i studied everything i could find, compiled what i thought to be true. then went to work.
***WARNING BEFORE YOU READ TOO FAR THIS ENDED UP NOT WORKING, MAYBE SOMEONE ELSE CAN GET IT****
I decided i could use the existing main harness wiring for the camera, instead of running the vid wire the length of the truck. Here is what i found.
Under the truck I found this:
This connector had many wires coming in, but not all coming out, upon closer inspection some of those were the camera wires, as per the wire diagrams and forum entries i had read. So I tapped in. In ended up with this.
Great! Now on to the front!
Up under the dash behind the glove box, hidden behind the Sync module, i found this:
Corrrect wires colors, unused, it fit the description. So, I tapped in...and....NOTHING.
Back to trouble shooting. Found out the power in the harness in the rear worked just find, as did the ground. But those VID+ and VID - did not make it up front.
I gave up here, and just ran the video wire from the camera to the head unit. Works great now. (If i had the HARNESS diagrams (Not the wiring diagram) i probably would have figured it out, but it was late, the wife was calling with an increasingly agitated tone.)
Good Luck.
Pete
Pin 6 is not used.
Hope this helps
Pin 6 is not used.
Hope this helps
