Bellows Up Pipes E99
Old Jul 16, 2012 | 11:32 PM
MauleOne's Avatar
MauleOne
Hey, is it true that my E99 PSD can't use bellowed up pipes because the E99 turbo pedestal height is different then the latter models?
Old Jul 16, 2012 | 11:45 PM
BigAlsPSD's Avatar
BigAlsPSD
You can't use the Late99+ but you can use the 94-E99 ones
Riffraff Diesel: International Bellowed Up-pipe Kit 94-Early 99
Old Jul 17, 2012 | 05:04 AM
mongo75's Avatar
mongo75
Damn, at $370 more than the late 99 up pipes, ya gotta wonder if it's not just better to do a whole e99- late 99 swap. You can get a used turbo and rebuild kit for about the difference, then a used pedestal for another $50 or so. I'd look at both sides, or just spend $10 for 2 new donuts. You can gt them at NAPA, Chevy uses them for smallblock exahaust too.
Old Jul 17, 2012 | 06:57 AM
bad12jr's Avatar
bad12jr
A set of t4 up pipes and a s366 66/74 .91 charger can be had for about 1100 and just mod your ic pipes. Same amount of work as a L99 swap and you could just about pay for the material to mod your ic pipes and intake boot for what you can sell the stock spider for. All you move to a better much stouter Turbo.
Old Jul 17, 2012 | 06:03 PM
MauleOne's Avatar
MauleOne
Pipes
Whoa, is kind of pricey
Old Jul 17, 2012 | 06:12 PM
BigAlsPSD's Avatar
BigAlsPSD
Personally on an Early rig I wouldn't do it either, either convert to late or T4 setup, or...
Your pretty handy fabrication wise aren't you? I think I have seen some of your work, you could always install bellows into your existing up pipes, your self too. the bellows are around $25 or so. It's a lot of work, and fitment needs attention to detail, but it's more about what your time is worth vs upfront costs.
Old Jul 17, 2012 | 08:02 PM
fordpride's Avatar
fordpride
Home made bellow up pipes
https://www.ford-trucks.com/forums/1...-up-pipes.html
Old Jul 17, 2012 | 08:36 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
i agree.....go with a t4i turbo like an h2e or a qssb....better turbo thats moddable and rebuildable.....get a custom mount from irate or carson stauffer....DO NOT buy the hypermax kit....
agg_bagg
Mar 19, 2011 12:55 AM
97powerstroke350
Jun 25, 2010 09:21 AM
rat49f6
13
Sep 2, 2009 03:34 PM
dnooner16
Jan 21, 2009 08:56 AM
dmncoon
May 31, 2008 07:06 PM
