Can't get hood open!
Old Jul 16, 2012 | 07:07 PM
Godlover's Avatar
Godlover
I picked up a parts 65 3/4 F100 Camper Special today that was in a fire. It has a 390 with a 4 speed but due to the fire I can't open the hood. I tried using a pry bar on the latch but it is stuck. I looked to see if I could somehow use my saws-all but not really sure how to do it. Any thoughts?
Old Jul 16, 2012 | 07:21 PM
StevenhF100's Avatar
StevenhF100
Did you try using PB Blaster or WD 40 2 or 3 times and letting it set for a day between each soaking?
Old Jul 16, 2012 | 07:46 PM
63' f100's Avatar
63' f100
Try lifting on the left side of the latch instead of with your right hand, thats how i have to open mine.
Old Jul 16, 2012 | 07:53 PM
Godlover's Avatar
Godlover
I got it open - thanks. I used a screwdriver and pry bar to get the latch open - but then the hinge was totally froze up due to fire - bent the hood opening it but the hood is toast anyway.
Old Jul 17, 2012 | 12:24 PM
daveengelson's Avatar
daveengelson
For info purposes: Took the truck to neighbors house so he could check out the engine, he made a comment on how difficult it was to lift and lower the hood, opening was not as difficult but occasionally had to pull hard to lower. Before we got into discussing the engine he reached for a aerosol can of Silikroil penetrating oil; I never heard of it, and applied a couple squirts to the hinges, don't ever recall the hinges working soo smoothly. Subsequently rebuilt front suspension and applied simikoil to the idler, ball joints, etc., the night before and IMO helped in the disassembly?
53Mercdriver
Jul 14, 2014 11:34 AM
f250red
Sep 9, 2013 04:22 PM
Larzon
Jan 31, 2012 08:21 PM
rastenburg
Paint & Bodywork
Jul 30, 2009 09:15 AM
