ABS Questions @ sensor
Old Jul 16, 2012 | 01:19 PM
ilateapex's Avatar
ilateapex
Van: 2005 E350, V-10, Torqe Shift, 3.73 Open diff.
I just had my semi-float axle replaced with a full-float axle. I ran the build code on the axle and it all seemed good as it was for the correct years and with ABS.
The semi-float axle had an abs sensor in the axle housing. The full-float seems to have wheel sensors. The PCM gets speed signal from the transmission (so I have been told).
My question is, is there any way to get the ABS to work with the wheel sensors. OR, do I need to add a reference disk to the gear and drill a hole for the original sensor? I plan on adding a limited slip so could add the reference disk then.
Thanks,
Michael
66F100Again
Jun 24, 2024 12:46 PM
1982_f150
Nov 6, 2016 10:16 PM
1995droptopz
Jul 15, 2011 09:48 AM
purecty
Apr 6, 2008 02:58 PM
BigWhiteTurdVan
Aerostar
Mar 17, 2003 11:15 PM
