front breaks hangin! helppp
Old Jul 16, 2012 | 09:28 AM
Rollin.IH.Coal's Avatar
Rollin.IH.Coal
86 6.9 just got her running. Calipers are grabbing. Push the break when driving and they bite n slowly release. But not all the way. Ideas?
Old Jul 16, 2012 | 10:46 AM
Phy's Avatar
Phy
A lot of folks have had flex lines collapse internally causing calipers not to release...
Old Jul 16, 2012 | 12:44 PM
Rollin.IH.Coal
That was a thought. Them rubber lines collapsing
Old Jul 16, 2012 | 04:29 PM
38Chevy454's Avatar
38Chevy454
Also if the truck sat for a long time, it could have some corrosion and dirt on the caliper pistons causing them to hang up a bit. There is a rubber seal on outside, not the real hydraulic seal on the inside. Disc brakes only have the rubber seal to pull the piston back, no springs. Flex lines can break down and have trouble releasing. You might consider just getting rebuilt calipers and new flex lines, fix it all with new parts.
Old Jul 16, 2012 | 10:32 PM
86sixbanger's Avatar
86sixbanger
x2. Brakes are something not to skimp on. New pads and calipers are cheap and easy to replace.
Old Jul 17, 2012 | 08:35 AM
Rollin.IH.Coal
Yeah calipers and lines are needed. As well as an axle seal. And an IP.... and wireing......
andysam
Jan 5, 2014 01:46 AM
halaferd
20
Oct 18, 2011 06:50 AM
parr4
Oct 20, 2010 11:33 PM
fd1109
Sep 22, 2008 04:41 PM
kens72highboy
Jun 21, 2004 07:47 PM
