HELP!! 79 ford f150 problems
Old Jul 15, 2012 | 12:56 PM
HatleyT's Avatar
HatleyT
Ok i have a 79 ford with a 4604 and i cannot get the truck to crank from the key. I can jump it off with a screwdriver from the starter solenoid but as soon as i remove the screwdriver the truck will cut off. And the starter is also sticking and will not disengage. What can i do to keep my truck running!
Old Jul 15, 2012 | 12:57 PM
HatleyT's Avatar
HatleyT
460 big block
Old Jul 15, 2012 | 01:13 PM
GOVTMOD's Avatar
GOVTMOD
You have a bad ignition switch and/or a bad solenoid. Easy fixes both. You might want to change out the starter too if it makes you feel better.
Old Jul 15, 2012 | 01:32 PM
HatleyT's Avatar
HatleyT
I replaced the ignition switch already and that is the 3rd solenoid in 2 days
granny_rocket
Sep 23, 2015 04:39 PM
rknctryboy86
Aug 2, 2012 07:31 AM
cfassett87
Jun 25, 2012 08:49 AM
bayslayer
Dec 5, 2011 04:26 PM
95f250
Sep 20, 2009 01:53 PM
