88 e150 needs more pulling power
Old Jul 17, 2012 | 10:22 PM
Club Wagon's Avatar
Club Wagon
Reread this thread.
Originally Posted by happyguyz
So with that note, what does this forum suggest I could try next to help with my poor power under load??
Take your pick. Or do as you like.
Old Jul 17, 2012 | 11:15 PM
Vanaddiction's Avatar
Vanaddiction
When I suspect a plugged exhaust, I FLOOR it, and be ready to lift my foot if it revs up like it should. If it only revs up to around 3000 ( throttle WIDE open ) and wont go past, the exhaust is usually restricted. It can seem fine at smaller throttle openings, but as you open the butterfly further, you reach a point where you begin to lose power.
I stress, the test won't prove anything if the pedal is not opening the throttle all the way. Or if there is a choke closing off the intake, extremely dirty air filter, mouse nest etc. (Mouse nest could be on intake or exhaust side)
Old Jul 18, 2012 | 02:35 AM
joshofalltrades's Avatar
joshofalltrades
i don't like the sound of that WOT test. the LTD i used to have had a cat melt down, and it was an absolute dog at lower RPMs, but made more power as the RPMs got higher. i never found a point where it dropped off at higher RPMs compared to lower while in the same condition.
you raised a question about the timing - if its not right, that could cause severe loss of power, most noticeable under load. pull out the timing light and make sure its set properly at idle, and make sure it advances as you rev it up.
scottgreer
Oct 20, 2014 08:27 PM
Rico47635
Jan 28, 2011 09:00 AM
wickedgood
13
Jul 15, 2008 08:18 AM
robertbourque
May 2, 2007 01:04 PM
Dannym
Jun 22, 2004 10:53 AM
