Front end sloppy when turning
Old May 9, 2003 | 06:51 PM
bettamanpj's Avatar
bettamanpj
Unhappy Front end sloppy when turning
I recently hit a sizeable pot hole at about 35mph and it seems to be reeking havoc on my front end...when in park and turning wheel left to right the car seems to roll side to side alot more than usual, and when making tight and not so tight turns at slow speeds the front wheel to which side i am turning seems to stick and not want to turn with the truck almost to the point where the the wheel will lock up and just be pushed along. At highway speeds and straight line driving it drives perfect. The turning radius at slow speeds is almost cut in half. Is this a wheel bearing, a joint, control arm?? Its a 1987 f-150 4x4. Thanks for the help.
Old May 9, 2003 | 07:11 PM
mrwizard's Avatar
mrwizard
Get under the front of the truck and have somebody turn the wheel back and forth. Look for any excessive play in any of the tie rods, ball jonts, etc...
