1978 - 1996 Big Bronco
Broncos
Old Jul 14, 2012 | 12:10 PM
1973F100Kid's Avatar
1973F100Kid
Broncos
Hi i have a 1991 ford bronco with a 351w. Yesterday i went offroading and mudding for the first time. When i got home i notice that my brake lights were on so i turned the lights of and they still stayed on. I checked i all fuses but nothing they still wont turn off. If anyone can help me i would really appreciate it. Thanks.
Old Jul 14, 2012 | 05:19 PM
Edgethis's Avatar
Edgethis
Check the brake light sensor up on the brake pedal under the dash. It prolly got bumped so it thinks the pedal is always depressed.
Edit... Also make sure your brake pedal is coming all the way back up, if not check for bad booster.
Old Jul 15, 2012 | 09:44 PM
1973F100Kid
Yeah i replace the brake light sensor and the lights still remind on. I also made sure the pedal is coming all the way up and it is but still nothing. How can i check the booster to see if thats the problem? Im starting to freak out cause i cant find the problem lol.....
Old Jul 16, 2012 | 01:17 AM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
If the booster is gone...you will know it...basically you will have to stop the Bronco like Fred Flintstone does.
Old Jul 16, 2012 | 12:09 PM
1973F100Kid
Lol but my brakes work fine. Its not the brake light in the dash that is on its the my brake lights on the back thats on. And i dont know how to fix that you know.
Old Jul 16, 2012 | 01:10 PM
ManfredVonRichtofen
For the brake lights to stay on like that..it has the be the brake switch.
Once you push in yer brakes it opens the circuit on the switch to give yer brake lights power to turn off. You will have to adjust it if it stays on. to adjust the switch you have to turn it so when you let go of yer brakes the button on the switch will push in and close the circuit.
choptop49ford
Dec 17, 2016 05:38 PM
captain2207
Sep 20, 2013 06:49 AM
codafisler
Nov 26, 2011 07:51 PM
brown78
May 27, 2009 07:43 PM
