6.0 running rough
Old Jul 14, 2012 | 11:37 AM
couse33's Avatar
couse33
6.0 running rough
i just had my inner oil cooler replaced,and had all injectors replaced,but the truck is still running rough at idiling and also run rough at 1500 to 2000 rpm, the shop i have it at show misfire on number 3 and 7 cylinder. they seam not to be able to figure the problem out. its been this way now for three weeks.any help would very approciated. also they told me to replace the ficm module and i had them do it and still the same results.
Old Jul 14, 2012 | 11:42 AM
f250rangerexplorer's Avatar
f250rangerexplorer
Welcome to the Forum. Theres a lot of good folks with a ton of knowledge here.
first off some info on your truck would be a good start.
Year, Mileage, Maint Hist, Previous Work, etc.
Why exactly did you replace all the injectors and oil cooler?
Do you have a scan gauge?
Old Jul 14, 2012 | 11:55 AM
couse33's Avatar
couse33
2003 f250 , 146000 miles the previous work i have had done to this truck was a egr delete on it.
the reason for all the work now was the inner oil cooler was bad.
Old Jul 14, 2012 | 12:18 PM
tex25025's Avatar
tex25025
Rough riding can be so many things. Leaking injectors, bad fuel pressure, hell even electrical issues could cause the computer to get bad signals that would cause a bad ride.
How is good does boost pressure build up? Leaking up-pipes can cause rough riding as well.
Old Jul 14, 2012 | 12:45 PM
cheezit's Avatar
cheezit
on an 03 it maybe icp sensor related.
need to check icpv @koeo looking for .19v give or take a few.
Supertommy68
Oct 31, 2016 03:37 AM
53jimc
Jun 1, 2016 06:59 PM
Hellbringer
Nov 14, 2014 10:26 AM
riverrush1
Feb 26, 2014 11:22 AM
Magnus E
Sep 6, 2013 04:52 PM
