Front bump stops?
Old May 9, 2003 | 02:52 PM
MustangGT221's Avatar
MustangGT221
Front bump stops?
I just got a 6" skyjacker lift that I'm in the process of installing. It gives you small brackets that drop the bump stops. My question is, how do you get the bump stops off? There isn't a bolt in the middle like I thought there would be. Any help would be appricated thanks.
Old May 9, 2003 | 04:23 PM
steve83's Avatar
steve83
Front bump stops?
The stud comes up into the frame rail, and the 15mm nut is probably recessed inside the spring tower.
Old May 9, 2003 | 06:02 PM
MustangGT221
Front bump stops?
When I reached me hand behind the spring tower I couldn't feel a nut. I'll take a closer look but there wasn't a nut above it to the best of my recollection.
Old May 9, 2003 | 10:26 PM
steve83's Avatar
steve83
Front bump stops?
Sorry - I dug one out of my junkpile, but it turns out I picked up a REAR bumpstop.
The front ones have a bolt with a small head (don't remember the size) and it's sunken thru the frame rail into the bottom lip of the spring tower. You'd need a light & a mirror to see it, but I think you can get a wrench inside the crossmember if you jack the frame up & let the axle sag.
Old May 9, 2003 | 11:37 PM
MustangGT221
Front bump stops?
Whole front axle is out...there's no suspension in it so I should have an easier time. Thanks.
