Music Making Engine
Old May 8, 2003 | 05:18 PM
youbetcha77's Avatar
youbetcha77
Music Making Engine
I have a 1988 Ford F-150. I think I already posted this but couldnt find it. But when I first start it after it has sat awhile its knocks once or twice. It really gets with it when you change the oil. Till the oil filter fills up the bearings all make noise then it instantly stops. Should I put bearing in this or not? It has only 100,000 miles on it. It has had regular oil changes. Can the oil pan be removed without raising the engine? Thanks
Blaze
Old May 9, 2003 | 05:25 AM
youbetcha77
Music Making Engine
According to the service book you have to jack the engine up to take the oil pan off. Has anyone done it sucessfully without doing that?
Old May 9, 2003 | 07:50 AM
steve83's Avatar
steve83
Music Making Engine
You should fill the filter before you install it.
Old May 9, 2003 | 09:02 AM
eckart's Avatar
eckart
Music Making Engine
Whats your oil presure like when its running. Its not a lifter that bleeds off?
Old May 9, 2003 | 09:35 AM
millertime300's Avatar
millertime300
Music Making Engine
I would just run thicker oil for now. The bearing are getting tired, but they aren't dead yet.
Old May 9, 2003 | 10:54 AM
mrwizard's Avatar
mrwizard
Music Making Engine
What brand of oil filter are you using? Fram maybe?
Old May 10, 2003 | 12:21 AM
youbetcha77
Music Making Engine
Its almost impossible to fill the oil filter first before you put it on because it sits on there dead butt sideways. Im not that fast to hurry and slap it on there even half full. I use Motorcraft FL-1A oil filter and Valvoline 10w-40. It did have quaker state ran in it. The engine is very very clean on the inside. So that makes me think that the people that had it changed it regularly.
Blaze
Can I take this oil pan off with raising the engine?
unibody62
31
Oct 15, 2013 08:50 PM
pickenspolitics
18
Aug 10, 2013 07:01 PM
FordEdselFanatic
19
Feb 13, 2009 12:12 PM
witman
Mar 14, 2006 09:50 AM
